Xenón headlight cleaning system
Old Mar 22, 2026 | 11:15 AM
javier500sl's Avatar
R107, R129, A208
My A208 has xenon cleaning systms that are mandatory in my country
Different from another cars, in the A208 thee is a switch , over the radio, that once pressed , a stream of water is pushed over the headlights
In my case, when the butting is pressed , the water is only pushed during one second, and then it stops.
i have replaced the pump and injected direct water to verify it is perfectly working
i have now the doubt if the one-sec functioning is normal, as it is not time enough to clean the headlights
do your cleaning systems works until the switch is depressed or either is just one second?
thanks a lot
Old Apr 7, 2026 | 11:20 PM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
Yes. 0.5-1.0 second high pressure burst is normal.
-John
Old Apr 13, 2026 | 02:55 PM
ML Dude's Avatar
[QUOTE=javier500sl;9274476]My A208 has xenon cleaning systms that are mandatory in my country
My W208 doesn’t have it but I remember wanting it. But I decided not to pass up the CLK430 I found after researching the headlight wash. It seemed to be of limited use and not for things like dried bugs!
