Headlight lenses
Headlight lenses
I just saw a clk with headlight lenses that were completely clear on the bottom half, and the normal "reflectory" type on the top half.
Why is this?
They look much better than mine do, which are the regular unclear glass all over, can i swap the lenses over or is there more to it than that?
Also can any recommend the whitest, brightest bulbs available for the standard non-xenon headlights, as mine look yellow like theyre from a 1970's car!
Why is this?
Why is this?
Why is this?
what do you guys think of these:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
are they worth it and do they replace just the dipped beam and the full (flasher) beam, or just the sidelights(smaller lights by the w208 grille)?
thanks
thanks
Those won't give you the clear lens look you're after. They only replace the main headlights (the larger ones) and don't have anything to do with the high beams, unless of course, you choose to replace the high beams instead of the low beams, or buy two kits (4 bulbs/ballasts).
I have an OEM Euro Xenon setup w/ an additional Hella HID retrofit kit in my high beams.
