water/moisture in foglight houseing
335is
ok so a few weeks back i bought some fog light bulbs cause one of them burnted out... after talking with my bro about it... it seems like the fogs burn out easily.... and today after reviewing through some pictures i took randomly... i can see moisutre inside hte fog light houseing.... this is not normal right? r there known issues about water leaking in? it seems like both sides have this issue... and i made sure the watertight seal is closed tight.... no wounder the fogs on this car burns out so easily... i'll post pics later tonight when i get time... now i have to go to movies..
1 Post
2001 CLK320, 2003 E320
Most likely your seals have hardened. This is a common problem with these fog light housings. All you need to do is replace the inner and outer seal.. apx. $10 for both..
You need #5 & #6 in the illustration.
Good Luck!
Good Luck!
