pedals
Old Apr 5, 2005 | 07:56 PM
blinkbass23's Avatar
E 63 AMG
pedals
ordered amg pedals on ebay dont know if they fit clk 500 w209 are there such aluminum pedals that can replace rubber
Old Apr 5, 2005 | 08:24 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
why not get original mercedes pedal rubbers from either the R230 SL or W203 those will fit without a single doubt those will most probably be cheaper then the fake AMG ones some people offer on ebay those will not require drilling and bolting of items as simple as pedal rubbers
greetingz,
Old Apr 6, 2005 | 11:56 AM
H-MAN's Avatar
'07 Carrera S, '31 A 5W hot rod, 4Runner. Sold CLK55
This is how they look on my W208 car, assuming they are the same ones.
https://mbworld.org/forums/showthrea...ght=amg+pedals
Old Apr 6, 2005 | 02:03 PM
clk04's Avatar
like steve says, go to the parts department and get the real deal
here are the part numbers: (the accelerator is expensive because you need to get the whole unit as opposed to the pedal sheath itself)
230-300-01-04 accelerator $134.00
230-290-00-82 brake $8.75
230-430-00-84 parking brake $7.75
Old Apr 6, 2005 | 10:05 PM
MBenzNL's Avatar
some slow@$$diesels
Originally Posted by clk04
lthe accelerator is expensive because you need to get the whole unit as opposed to the pedal sheath itself
...unless you buy the 15USD one for the SLK...then you can just take the rubber/aluminum cover off and swap it with the rubber cover in the CLK...
greetingz,
Old Apr 10, 2005 | 01:12 PM
clk04's Avatar
ya but then you get the problem of having oval rubbers on the other pieces and the circle on the accel
Old Apr 10, 2005 | 02:02 PM
Frisco's Avatar
03 CLK500, 04 X3, No 07 GT3RS :(
I have the SLK/SL pedals and it cost me about $45 through the parts window at my dealer - the oval vs circle thing really isn't noticable to me.
Old Apr 10, 2005 | 06:47 PM
cliffybabe's Avatar
CLK Coupe 200 Komp 53 Plate
Here's my pedals
Before:
After:
Neil
Old Apr 12, 2005 | 01:46 PM
clk04's Avatar
i suppose its just a matter of personal taste, but i like the oval ones of sl better. also, note cliffybabe's picture: the footpedal has the oval rubbers and the other two the circle rubbers. thats what will happen if you mix and match slk/sl pedals
Old Apr 12, 2005 | 03:34 PM
clkcadet's Avatar
S550
i actually got the oval rubber pedals from ordering the appearance package when i look at the circular rubber pieces i like mine much more, but again its probably a personal prefrence to be honest if i didnt have those im sure the standard rubber pedals would do just fine
