SRS Restraint System Malfunction Error w/ only 1400 miles!!!
Old Apr 18, 2005 | 04:26 AM
MothXz's Avatar
2005 CLK 320
As I went to use my car the other day I noticed an error saying SRS Restraint System Malfunction-Immediate Service required. Is this a serious problem that I should worry about? The car only has about 1400 miles on it. I'm assuming this is all under warranty so will I be expected to have to shell out any money to fix this? Thanks in advance.
Old Apr 18, 2005 | 02:58 PM
calboy's Avatar
2003 CLK 320
I had the same problem, and it took two visits to fix. The first time they replaced the cables because the resistance was off. The next time they replaced the harness. Probably a bad connection for the sensor.
