CLK 500 Transmission problem.
Old 11-09-2005, 12:33 PM
lauer87's Avatar
E550
Hello all, im sorry for those of you who are experiancing problems. I have a 05 clk 500 as well and i love the 7 speed (so far), and the gearing with the V8 is absolutely perfect imo.
Old 11-09-2005, 02:22 PM
pisces777's Avatar
2005 CLK500
I like the 7-speed transmission but just like many of you guys, i'm having the same problem in the morning. The car downshifts violently to 1st when i come to a stop. The car is fine after two minutes of driving. I got used to it.
Joe
Old 11-09-2005, 09:48 PM
gambri's Avatar
05 CLK500
I like many of you have the same problem, especially in the morning, took a lil while but i got used to it
Old 11-10-2005, 05:22 AM
robertus's Avatar
CLK55 AMG 2006 Cabrio, BMW M3 2008 DTC Cab new (M3 e46 SMG 2003 Cabrio Sold), BMW X5 tt Diesel 2008
Hi All,
The problem in Australia is we pay double the price for these cars, so if you can imagine that you layed out twice the amount of money for your car in the US and had these problems you would not stand for it.
So when you have a problem with your MB here in Australia the **** hits the fan big time because in the back of your mind MB cars are driven as taxi's in Germany.
There is no excuse for poor product especially from highend manufacturers, I cannot believe the treatment you seem to recieve from your dealers in the US but then again they are like any business, once they got your money they do not want to know you anymore unless you buy 2 or 3 cars very couple of years.
Robertus
Old 05-30-2014, 02:53 PM
dew1956's Avatar
2006 clk500 convertible
CLK500 transmission slipping
While driving in sport mode transmission is slipping between 1st and 2nd.
Seems to work fine in comfort mode. Any ideas on what the problem is
and cost to repair?
Old 05-30-2014, 10:33 PM
MBworld Guru
Rudeney's Avatar
Received 1,002 Likes on 870 Posts
NO LONGER ACTIVE
Could be low fluid. The 722.9 is a bit more involved to check than the 722.6. It lacks a dipstick. You have to check via "overflow", so you have to have the car lifted, level with the engine running, then get beneath to remove the drain plug, pump in extra fluid, and at the right temperature, check the flow rate. If this sounds complicated, then it may mean a trip to the shop for a proper diagnosis.
Old 06-01-2014, 09:38 AM
  #32
dew1956's Avatar
Thanks for info. I hope all it needs is a little fluid, headed to the shop tomorrow.
Dave
Old 06-03-2014, 02:09 PM
  #33
kb24forlife24's Avatar
None for now
Dave
Please let us know what the results are, I have the same exact problem. Thanks
Old 08-01-2014, 05:22 PM
  #34
dew1956's Avatar
My transmission (7 speed) was slipping between 1st and 2nd gear. Had my transmission fluid changed it was black. After 2 or 3 weeks it was working fine. keeping my fingers crossed. Good luck.
Old 10-21-2014, 05:43 PM
  #35
Tekee3137's Avatar
CLK500
CLASS ACTION?
Hi, Does anyone know if there ever was a recall or class action filed on the 722.9 transmission? I have a 2005 CLK500 acting up and see from these posts there are many others out there like myself. Please advise?! Thanks a lot! Nicky
Old 10-21-2014, 10:04 PM
  #36
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
MBZ doesn't do recalls unless the NHTSB requires it. Class action suits do no good - no one is going to force a manufacturer to cover things post-warranty. This failure (assuming you are talking about the turbine speed sensor problem) is due to a defective $20 part supplied by Siemens. Unfortunately, it takes out another $1200 part and then takes another $500 in labor and fluids to replace. Siemens (and most other suppliers) contracts with MBZ don't require them to pay the high cost of this repair - they only have to warrant their part.
Quick Reply: CLK 500 Transmission problem.
