rim fitting for our car
CLK 500 04'
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
just wondering if 35mm offset rims 19X8.5
5X114.3 Bolt Pattern
245/45/19 front tires
275/40/19 back tires
will fit our cars????
thanks
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
thanks
Mercedes
I'm running 235 front 265 rear and I'm experiencing some rubbing in deep turns, dips in the road, and bad bumps. Are you guys experiencing this, too? I have 19x8.5 front and 19x9.5 rear 37mm offset all around with 12mm spacers for the front and 20mm spacers for the rear. Is there a way I can fix this at a minimal cost? I'm wondering if I should use smaller spacers, but I'm worried about rubbing with the suspension pieces. How much does having the fenders rolled cost and what does it actually do?
03' CLK 55 AMG
I don't think you would want to get 45 series tires for your front and 40 series in the rear. Your tires would be too big, You need to get and they will probably recommend you getting 35 series in the front and 30 series in the rear.
Mercedes
that's the thing, I do have the 35 series in the front and 30 series in the rear. The wheels should fit. I don't know why it's rubbing, other members have the same set up 19x8.5 and 19x9.5 235/35/19 and 265/30/19. I calculated the offset using a wheel offset calculator I found online where you punch in the old rim's width and offset and the new rim's width and offset to tell you what spacer you need but I'm starting to think it might be incorrect.
Mercedes
Originally Posted by x-tian-230k
Isn't the bolt patter on our car 5x112? So will 5x114.5 fit?
1 Post
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
thanks
thanks
03' CLK 55 AMG
Chi, what rims do you have and what are the offsets on both the front and the rears? It might be rubbing because of the spacers you have on. By the way, where do you feel or see it rubbing at?
Mercedes
CLK 500 Convertible
I have 19x8.5 front 19x9.5 rear and the offset is 44mm in the front and 46 mm in the back. I have 25 mm spacers front and back. I also here it on very hard turns in the back (both sides). I don't have any problems with road bumps! In the front i don't here anything, but i took off rims and saw that it is also rubbing, but so little that you can even here it. Maybe 19th are to big for the clk.
Mercedes
I think the spacers we are using are too big but I'm not sure. I checked on the wheel offset calculator http://www.1010tires.com/WheelOffsetCalculator.asp Onekel, looks like you only need 20 mm up front.
CLK 500 Convertible
if i would put 20 mm in the front they would rub even more!! because they rub on inside on the blastic (im Radgehäuse), not on the fender on the outside in the front! i hope you understand what i mean Chi
