CLK W209 Picture Thread
i have serious problems with the fronts they touch the car when i turn the steering wheel .what can i do?
i must say it look awesome but ride quality is not anymore a benz .!!!!
Do you mean the tires are rubbing the fender or the inside?
Are your offsets on the new wheels about the same?
Might be able to get your fenders rolled if the outer part of the tire is making contact or get spacers if it's rubbing on the springs or perch.
Good luck.
http://hrsprings.com/scripts/appguid...0|%20CLK%20320
I don't know what your offsets are on your wheels, but on my fronts the offsets is ET35... and then I put a 15mm spacer upfront. What you'll be doing with the spacers is pushing your wheel more toward the fender... widening your stance.
I'd reccommend getting spacers for the rear if you're going to have spacers up front. Otherwise, it'll look kinda funny.
problem solved
wrong tire pressure
thats weirdo though
how can less tire pressure make a tire start rubbing the inside??????
amg australia suggests 7.5 for the fronts i think mines are wider
a question.
does changing the factory ofsets change the geometry of a car and make it "dangerous"?
from what i understand also installing spacers change the ofset,is that right?
Its complete wrap with Vinyl
And yes, its the C55 AMG Grill in black
@ dynomite05
I paid 1.700 € for this
Here are the pics:
CLICK
You wrapped the whole car?
