Climate Control
Old Jul 5, 2006 | 08:21 PM
mis3's Avatar
2004 CLK320
Climate Control
For my 2004 CLK320 Coupe, I noticed that when I set the climate control in Auto, the air would come out only from the front vents, not from the top or bottom. I checked this out when I went on a trip recently. I noticed that for 5 hours, no air came out from the bottom vents for the whole time.
Is this normal?
Old Jul 5, 2006 | 11:59 PM
Toog4me's Avatar
G63, AMG GT S
When you click AUTO, it sets everything to the best point. It distributes the air through the vents that will cool/heat the car the quickest and the best-- and that's what your two front vents will do.
So yes, that's normal.
Old Jul 6, 2006 | 10:47 AM
mis3's Avatar
2004 CLK320
OK. I thought the Auto setting will distribute the air flow between all the vents (front, top, bottom).
Old Jul 6, 2006 | 09:06 PM
SUNILP's Avatar
2015 E250D
It depends on the temperature of where you are at. If it's really hot then it will continue to blow from front only. There is a setting which can be programmed so the floor vents don't come on with the a/c in auto mode. This is done via Star Diagnose and your car may be programmed this way.
Old Jul 7, 2006 | 01:44 AM
clkcadet's Avatar
S550
i hate this ac unit, i barely feel anything unless its at 5 bars
Old Jul 7, 2006 | 05:30 PM
Toog4me's Avatar
G63, AMG GT S
it never gets cold enough... i cant stand it. my navigator has better ac.
