How to change headlight bulbs
Im just curious if its even possible to open and change the bulbs on a 2005 CLK 320. and if so does anyone here know how to or can direct me to a site or forum that can-thanks
S550
im not much of a technician, but here it goes:
-open hood
- when looking at where the light fixture is, you should see 2 circles that twist open, the bigger one is the low beam headlight
- twist the harness and pull out the bulb'
-change bulb
-twist and fasten the harness
-place the cap back on
- do the same on the other side
-open hood
-change bulb
I couldnt exactly find the two circles and tried to search on here how to, do you know of a link that places instructions and also how good are the H7's on the CLK 320's. and did you do chang the headlamp bulbs on your car?
S550
i had to replace one bulb due to it blowing out,
sorry i took a moment to search and try to find an older thread that had a diagram and highlighted the exact location, but i could not locate it.
best bet is to consult your owners manual
