Mp3
Mp3
My 2004 CLK320 coupe has the optional Bose stereo with cazette and CD changer. I am generally satisfied with the sould.
What do I have to change to play MP3?
S550
got an ipod??
if they have a dice kit for benz that would be best www.densionusa.com
if you have navi u just need a mini to mini cable there should be an aux input
Mp3
got an ipod??
Vehicle Incompatible
We do not have a DICE iPod Integration Kit that is compatible with your vehicle. If you would like to be notified when there is a DICE iPod Integration Kit available for your vehicle, please enter your e-mail address below.
what to look for?
I made that mod to mine and it works great. But this isn't for someone with no prior soldering skills. The circuit board that you tap into is rather small and the solder terminals are VERY small. You have to cut some slices into the circuit board to disconnect the tape's input to the pre-amp and then solder in some wires from an RCA cable. Very nice, cheap solution if you or someone you know has some circuit board soldering experience.
