heated seat problem .....
since yesterday passinger side heated seat is not working.(after my fat friend seat on that seat)
driver side is fine....
i m out of warrenties so... i don't wanna spend money on this...
please what should i do...
when i touch the heated seat buton no light is on.......
please guyz help me out
is it a simple problem? easy to fix it ?
Check the connections under the seat...Check for power to the seat heater plug at the seat..If Power is ok..then test the seat pads with a OHM Meter to see if you have a defective heat pad/pads
