Heated exterior door mirror of 04 CLK 320?
Old Jul 12, 2007 | 02:43 PM
dongshin's Avatar
Hi,
I just bought a 04 CLK 320 silver with 30k miles couple of days ago.
At the first day, I found that windshield washer fluid didn't come out, so I went to dealership. They tried, and it worked. What a shame! I needed to push the button harder!
Here, I have a question.
My current mirror is not an OEM and also it has some fog inside that does not wiped out, so i want to order mirror glass.
Is the heated door mirror default option in CLK class?
If it is, I need to order heating part as well.
Btw, my car does not seem to have the button related with a heated mirror.
Thanks.
Safe drive.
Old Jul 12, 2007 | 05:57 PM
moondust's Avatar
2004 CLK 240
I have had my 04 CLK for just over a year now and the exterior mirrors work fine. My understanding is that the glass in both exterior mirrors is heated as standard on W209. There is no switch.
My OH has the following brief information: "The mirrors are heated automatically at low outside temperatures"
This 'low temperature' cannot be adjusted.
Old Jul 15, 2007 | 08:49 PM
mis3's Avatar
2004 CLK320
I have a 2004 CLK320 and I had this same question a few months ago. I wrote to MB Canada and this was their reply:
"Thank you for your inquiry. Please note the outside mirror heating will
turn on depending on outside temperature (as displayed in the instrument
cluster) and on outside humidity (measured by the humidity sensor belonging
to the AC system). 5 degrees Celsius is generally the switch-on
temperature, however it will switch on at higher temperatures, depending on
humidity. Please note both outside mirrors will be heated at the same time
and the customer cannot turn this system on or off. Should there be any
outstanding concerns with the outside left-hand side mirror of your
vehicle, we strongly suggest that you contact your local authorized dealer
for diagnosis."
