Help !!
as the manual says -
Economy Mode
Air is neither cooled nor dried in economy mode.
Switching On
>Press the ACoff button.
the indicator lamp in the button lights up.
Switching Off
>Press the ACoff button again.
the indicator lamp in the button goes out. The previous selected setting is resumed.
It wasn't.
My car is an 04, this may be different for yours.
The light that comes on, which is located on the A/C button, disengages the A/C.
If the light is on...... the Air Conditioning will not work, it will just pull in the outside air.
Yeah, to see the car work correctly, set the temp really low, like 65 or less, and then hit AUTO. If your AC is functional, you will get cold air out of the main vents. I don't know about the color of the red light, but AUTO should get you in the right place.
If you set the mode or fan speed manually, you are asking it to do something different, possibly something confusing (maybe it's just my car).
