IS UR W209 DROPPED? PLEASE SHARE STORIES/PIX
Old 04-16-2008, 08:55 PM
BelaMeca's Avatar
Location: Los Angeles,Belgrade.Current Residence Zurich.
2017 Mercedes Benz E220D/GONE!JUNK!Current GLC Coupe 350d 4 Matic
here's my two clk's both lowered.(and other cars)
As you can tell all of my cars have been lowered,i would not have it any other way!just change the springs,don't mess with anything else if you want to keep some comfort.I usually use H&R or Eibach.Depending on the Vehicle.On my 55 i went with H&R,and i'm totaly fine with the way it rides.
Old 04-16-2008, 08:59 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I see you have the smoked out corners on the white CLK. I want to see a nice side pic once you put yours on!!
BelaMeca's Avatar
btw,
the Z and G have not been lowered in the pics shown.I used the wrong pics.
Old 04-16-2008, 09:01 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
btw,
Should paint the calipers on the G red!
Old 04-16-2008, 09:10 PM
BelaMeca's Avatar
Yeah im getting my cool smoked corners soon!
Bought it from this guy,his name is Ricky Bobby!!!
Old 04-16-2008, 09:23 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Have you changed your brakes on your w209 or you still stock?
Old 04-16-2008, 10:15 PM
  #32
BelaMeca's Avatar
On the 320 or the 55?
Old 04-16-2008, 10:16 PM
  #33
dynomite05's Avatar
04 CLK 320 > CLK32K
both
Old 04-16-2008, 10:27 PM
  #34
BelaMeca's Avatar
stock brakes.
why you wanna change them?
Old 04-16-2008, 10:29 PM
  #35
dynomite05's Avatar
04 CLK 320 > CLK32K
Yea but I don't know where I can order the porterfield brakes.I tried formymercedes.com but the have for the 2003 clk 320. Would these be the same for the 2004?
Old 04-17-2008, 05:17 PM
  #36
peppernick's Avatar
10' E500 Sport
Mine on OEM Styling 4 2-piece wheels and H&R Sport springs. I retained the stock No.2 rear spring pads.
Old 04-17-2008, 05:22 PM
  #37
dynomite05's Avatar
04 CLK 320 > CLK32K
The ride looks real slick!! What size are the rims?(back and front) What # pads you have in the front?
Old 04-17-2008, 05:50 PM
  #38
M-bENZ's Avatar
Corrolla
If im not wrong his is 18".. and yes dat car looks damn clean
Old 04-17-2008, 06:38 PM
  #39
dynomite05's Avatar
04 CLK 320 > CLK32K
The thing is I going to be runnin 19x8.5f and 19x9.5r and H&R springs. I wanted to know what # spring pads I should put. I wanted to try and do it right the first time! I love Peppernick's drop but if he has 18's then I would probably need to go bigger than #2 in the back.
Old 04-17-2008, 06:41 PM
  #40
peppernick's Avatar
10' E500 Sport
I switched to 19"s. Those are the optional 2-piece wheels off the SL55, 19X8.5 fronts (ET 30) and 19X9.5 (ET30 + 10mm spacer) rears.
The W209s don't have spring pads that you can change for different thickness up front. You can only do such at the rear.
3/4 front profile shot.
Old 04-17-2008, 06:53 PM
  #41
dynomite05's Avatar
04 CLK 320 > CLK32K
Nice, So you don't have any spacers in the front right only 10mm in the back?
Old 04-17-2008, 07:03 PM
  #42
peppernick's Avatar
10' E500 Sport
That's right.
Old 04-17-2008, 07:27 PM
  #43
dynomite05's Avatar
04 CLK 320 > CLK32K
That's right.
So when you purchase the spring pads its just one for the rear left and one for the rear right? You don't have to buy 2 and 2 right? (I realize this might be a stupid question but I want to make sure I get the correct amount.)
Old 04-17-2008, 08:57 PM
  #44
M-bENZ's Avatar
Corrolla
dynomite05,
hey if u still want to low your car...check this out..remember that deal I told u before.
https://mbworld.org/forums/suspension-braking/236470-fs-koni-yellow-adjustable-shock-h-r-springs-w203.html
Old 04-17-2008, 09:02 PM
  #45
dynomite05's Avatar
04 CLK 320 > CLK32K
Originally Posted by M-bENZ
dynomite05,
https://mbworld.org/forums/showthread.php?t=236470
Thanx but I already bought H&R springs I just wanted to know about the spring pads. I think I'm going to go with #2 pads in the rear. Hopefully its turns out good.
Old 04-17-2008, 09:35 PM
  #46
M-bENZ's Avatar
Corrolla
Hey what kind of shock you going to use ?? bilstein, Koni or stock???
Old 04-17-2008, 09:43 PM
  #47
dynomite05's Avatar
04 CLK 320 > CLK32K
Stock for now. I have 56k miles so i'm probably gonna have to replace them soon anywayz and when I do imma go with bilstein!
Old 05-01-2008, 07:51 PM
  #48
illery's Avatar
CLK 320
Exclamation helpppppp
Okay guys im going crazy researching here and keep finding different answers out here. For any experts or people with great knowledge in this field. can someone tell me will my stock shocks blow/or wear pre-maturely anytime after I lower my car with just aftermarket lowering springs?
I really do want to lower my car in order for my new rims to sit nicely with it. However, currently this is my only dilemma.
I know BelaMeca mentioned to not mess around with anything else and just swap the springs but I dont want to sacrifice anything in the future and be in and out of the benz dealership and paying outta my *** for something that could have been prevented. I need help and if someone could straighten some things out for me I would really appreciate it.
Old 05-01-2008, 08:48 PM
  #49
dynomite05's Avatar
04 CLK 320 > CLK32K
I had the same thoughts before I made my decision! At first I just purchased the springs but after a few days of searching I read that the after market springs in the long run mess up the stock shocks and struts. I purchased the Blistein HD package. I have 56k miles and would of had to change them soon anyways.
Old 05-01-2008, 09:44 PM
  #50
M-bENZ's Avatar
Corrolla
H&R Springs go with Bilstein HD...perfect set up
Quick Reply: IS UR W209 DROPPED? PLEASE SHARE STORIES/PIX
