W209 Winter Wheels setup
What is your current setup? Curious to know if we are able to go with a non-staggered setup instead of the stock staggered setup, also are 17" wheels necessary or can we go a size lower to 16"?
Appreciate any feedback.
I should have gotten all four as the smaller 17x7.5 for TWO reasons:
1. The rear wheels spin easy in snow. Narrow is better
2. Rotation is key. You really need to be able to turn winter tires backwards so that the siping front edge can remain sharp. Four of the same size is best for this.
Directional tires are a big no-no for winter tires, because after ~3000 miles, they will actually try to slide on the snow. You need to be able to reverse the tires so that the cupping will actually help you instead of hurt. I've seen this first hand. Sliding all over in the snow, and then I reversed my directional tires and WOW much more grip!
I'm pretty sure 16" wheels won't fit. I visually measured for this and there is less than .5" clearance between the brake and front wheel. The rear has a LOT more room with the smaller brakes, so I'll bet 16" would fit fine, maybe even 15". Dunno.
And in case you weren't sure, the 7.5" wide wheels fit just fine on the rear, and in fact the 8.5" wheels fit on the front fine too, even with 255/40R17 tires! Lots o' options.
i'm suprised that 16"s wont fit on the front, are the brakes on the 500 that much larger than those found on the 350 where 16"s come stock?
I believe that is why the 350, with the sport package, gets 17" wheels, but without it comes with 16" wheels.
As an aside, I saw an 08 CLK550, and it used 18" wheels. I checked the brakes, and they are the same size we have. The front rotors have a lot more clearance. Thus they moved to 18" for appearance and handling, not out of necessity.
