AMG brake upgrade from SLK55?
Old Oct 4, 2008 | 09:55 PM
localbrew's Avatar
CLK500
Hello is it possible to upgrade CLK500 brakes from an SLK55 kit? Is it bolt on or is there modification involved?
Thanks!
Old Oct 6, 2008 | 02:05 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The AMG Six piston front brakes will bolt on..Nice Upgrade!
Old Oct 6, 2008 | 07:37 PM
Supafly's Avatar
I drive the racism out of BadDebt. ;)
The 6/4 pots from the SLK 55 is a drop in for the w209 CLK.
Old Oct 6, 2008 | 07:53 PM
localbrew's Avatar
CLK500
So would you say $1200 is worth it for the front and rear rotors and calipers? Is there any change in the size of the front or rear rotors or am I just getting more pistons per caliper? Thanks!
Old Oct 6, 2008 | 10:38 PM
Discgolfer74's Avatar
2003 CLK500
What model year?
Old Oct 6, 2008 | 10:52 PM
2003 CLK500
Originally Posted by Discgolfer74
What model year?
Nevermind... I answered my own question. The SLK55 came out in 2005 - 2008.
Old Oct 6, 2008 | 11:46 PM
localbrew's Avatar
CLK500
they are off a 2006
Old Oct 9, 2008 | 12:13 PM
localbrew's Avatar
CLK500
Rotor size
Can anyone tell me if the rotors are the same size from the SLK55 and CLK500? I know the calipers will match up correctly but I'm unsure of the rotor size.
Thanks!
Old Oct 9, 2008 | 02:22 PM
Thanks!
The rotors are different not the same the 55 has larger rotors
Old Oct 9, 2008 | 02:26 PM
M-bENZ's Avatar
Corrolla
wow its nice to know that the rotor from slk55 is differnt from CLK 500...
Old Oct 9, 2008 | 05:06 PM
2003 CLK500
So, if I do find SLK calipers, will I have to swap out my rotors too? If so, which ones do I use?
Old Oct 10, 2008 | 10:11 AM
Supafly's Avatar
you cannot use the original 500 rotors and SLK55 calipers. The SLK55 rotors are larger and of a 2piece floating design.
Old Oct 17, 2008 | 09:55 AM
reserved's Avatar
clk 500 (wifey's); 350Z roadster (daily driver); 350Z coupe (track car)
That sounds seriously inexpensive to me!!!! Is that price new or used?
Old Oct 18, 2008 | 02:04 AM
localbrew's Avatar
CLK500
It was used, I passed on it and I'm looking into Ksport 8 piston fronts and 4 or six piston rears. Going 14" rotors in front and either 12 or 13" in the rear.
Old Oct 19, 2008 | 07:58 AM
2003 CLK500
Here is New Price from Dealer:
"Here is pricing for you. They are available. I can get them within 3
days. I put a discount on there for you. Still pretty hefty. Let me
know if you decided to go with them.
PART NUMBER DESC LIST SELL
0034206783 LEFT CALIPER MFP 745.00 596.00
0034206883 RIGHT CALIPER MFP 745.00 596.00
Thanks!"
Old Oct 20, 2008 | 11:21 AM
JALE's Avatar
2003 CLK 500
what rotors would you use?
Old Oct 20, 2008 | 12:49 PM
localbrew's Avatar
CLK500
Thanks!"
You can get an 8 pistion kit with 13" rotors for $1560 on ebay. The AMG calipers are $1200 and then you'll need SLK55 rotors which are another $500.
Old Jul 18, 2009 | 07:49 AM
Carnol4's Avatar
2003 Clk55
could someone tell me if the front w209 clk55 4piston could be moved to the rear?, since later models carry that from factory? Im looking to upgrade the front axle to 6 or 8 piston, and hopeully move the amgs 4piston to the rear...
Old Jul 18, 2009 | 11:50 PM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
That's really cheap. The front rotors are like 1000-1200 each.
Old Oct 31, 2015 | 02:34 PM
performanceisla's Avatar
slk 32 amg
2013 slk55 amg to 2003 slk32 amg
any chance you can swap in the brake rotors/calipers from a 2013 slk55 amg into an older 2003 slk32 amg?
Old Feb 18, 2016 | 08:19 PM
DanBH's Avatar
SLK32
I measured my SLK32 AMG front caliper space and found that that the Mercedes 550 Brimbo calipers matched the drilled and slot rotors, purchased from DRT rotor sport. Found the front calipers (4 piston) off a 550 series, both for $125, these Brimbo brakes will work perfect, I have a lathe and made four spacers for the correct alignment, but you can use washers (not recommended). You'll need 4 longer bolts, remember to get the pitch right and use lock tight or they will come out!! Also as long as your doing the job, do it right, change to steel braided hoses and flush the system.
Result, my car brakes faster in a straight line with a lot less wear and heat so less brake fade on the track, just remember the guy behind you may not have the same system and you don't want him kissing your butt at high speeds.
Drive safe! DanBH
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
