lower the front
Old Oct 23, 2008 | 12:48 AM
ZEEK's Avatar
Yo Momma
lower the front
I dont know if many of you have this problem or not but my front is higher than my rear. I went to the dealer to ask about some spring pads thinking i can change the front pads and it will even out the car, but the dealer said these w209s dont have pads . Is it true? Did any of you have this problem? and if so waht did you guys do to resolve it?
Old Oct 23, 2008 | 02:37 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Only 50% true !!! Mercedes still used spring pad in the rear to even out the height. If you try to even out the fender gap, the rear will rise up.
Old Oct 23, 2008 | 01:00 PM
ZEEK's Avatar
Yo Momma
can't I just do something in the front to lower it to even out with the rear?
Old Oct 23, 2008 | 01:09 PM
wazv6's Avatar
'14 E550
even with lowering springs you'll have the same problem, i think the only way you can solve that problem is with coilovers. you'll then have the ability to even out your ride height
Old Oct 23, 2008 | 05:40 PM
localbrew's Avatar
CLK500
I don't recommend this but you can cut a little bit of the coil off if it's that important to you. Or go coilovers.
Old Oct 23, 2008 | 06:41 PM
ZEEK's Avatar
Yo Momma
so how come the lowered clks that i see here are evend out? they must be on coilovers? and how much do these coilovers cost.
Old Oct 23, 2008 | 06:56 PM
wazv6's Avatar
'14 E550
if there even'd out then odds are there on coils. coils are not cheap espically for our cars. i've been shopping for a set of coils and the cheapest i've found were from a company called K Sport and they quoted me at $1500, cheapest ive seen bilsteins for were for $1800 on tire rack and KW are even more $$$$
Old Oct 23, 2008 | 07:05 PM
ZEEK's Avatar
Yo Momma
this is fkin crazy. **** man.
ZEEK's Avatar
Yo Momma
how about we cut the front springs a little bit?
Old Oct 23, 2008 | 07:12 PM
wazv6's Avatar
'14 E550
i highly reccomend you dont cut springs, its unsafe man, i've known a few guys who had cut springs mostly on honda's and didn't turn out too good for them
Old Oct 23, 2008 | 07:38 PM
ZEEK's Avatar
Yo Momma
thanks a lot for the help man...
Old Oct 23, 2008 | 07:47 PM
localbrew's Avatar
CLK500
check the classifieds bro, there are a lot of used coilover kits out there.
Old Oct 23, 2008 | 08:28 PM
Klinh's Avatar
Even with coilover kits like KW, on the Clk and C-class, you will need wheel spacers in the front to lower your car all the way down. I wasted $1800 on the KW kit. I removed the kit only after 2 weeks because of the rubbing problems and the ride is too stiffed for mine Clk 500 Cabriolet even at the softness setting. I decided to go with Eibach spring and Bilstein sport shock. I then changed mine rear spring pads to even out the fenders gap with the front. I love the new ride.
Old Oct 23, 2008 | 09:45 PM
ZEEK's Avatar
Yo Momma
so you lowered the car first then changed the rear pads to raise it a little bit so that it can even out with the front? is that correct?
Old Oct 23, 2008 | 11:01 PM
Klinh's Avatar
Yes but depending on your car weight and spring brand, you will have to decide to go with thinner pad or thicker pads to get the fender gap even all the way around. This is how my car look.
Old Oct 23, 2008 | 11:06 PM
ZEEK's Avatar
Yo Momma
your car looks great.
Old Oct 23, 2008 | 11:07 PM
ZEEK's Avatar
Yo Momma
btw, what kinda pads you have right now?
Old Oct 23, 2008 | 11:45 PM
Klinh's Avatar
My car is totally different then your in term of weight due to the V8 and convertible. The brand of spring also lowered the car different too. I'm currently using pads #4.
Old Oct 23, 2008 | 11:50 PM
ZEEK's Avatar
Yo Momma
actually i have a 03 500 as well. I need to change my profile. But yes 500 conv is diff.
Old Oct 24, 2008 | 12:37 PM
localbrew's Avatar
CLK500
Personally I'd go Koni's, I've used bilsteins before and I love the Koni's
Old Oct 24, 2008 | 03:11 PM
ZEEK's Avatar
Yo Momma
i think first im gonna go with H&R sports then get konis later because money is tight right now.
Old Oct 24, 2008 | 08:07 PM
stormkenny3's Avatar
clk 500 2003
yeap H&R springs are cool am planning them soon.
Old Oct 24, 2008 | 08:52 PM
Klinh's Avatar
The H&R spring usually drop alot more then Eibach spring therefore, I don't think the factory shock able to handle it. I try the Eibach spring with the factory shock on my car and the rebound were very loose on my car.
Old Oct 24, 2008 | 10:04 PM
ZEEK's Avatar
Yo Momma
but if i remember correctly, localbrew had dropped his car with H&Rs first t hen he got konis later. How was your ride with H&Rs only localbrew?
Old Oct 25, 2008 | 02:39 AM
Klinh's Avatar
You can if you want but I'm just saying that if you don't mind driving your car bouncing and your shock will get destroy faster.
