2003 clk500 springs
2003 clk500 springs
Okay so I've done a lot of suspensions in the past and ive been hearing people say i wouldn't be able to lower it because of the lowering sensor or something. I know theres always a way around it. Plus i didnt see anyone complaining about sensors. Would h&r springs without aftermarket shocks be ok? I tried searching and no lowering sensor came up. Thanks for your help in advance.
04 CLK 500, 07 GSX-R 750, S 550, 09 Jeep GC
You can lower your car with the H&R Spring with out any trouble, as far as a leveling sensr goes, the W209 Clk does not have the airmatic or active suspension as some of the heavier/ exoensive benzes do. I am personally running the H&R spring on my CLK 500, installed myself in my garage. It took a good deal of the play out of the suspension. the only issue with it if I would even call it that is, when riding with a car full of people becareful that you don't drive to aggresively or sometimes rear tire will bottom out into the felt lining of the wheel well.
