Problems with Garage door opnener
Old Jan 31, 2009 | 04:49 PM
ark1tech's Avatar
2003 CLK 500
Hey guys, I have been trying to program my garage door with my car (2003 clk 500). I used the book and followed the instructions carefully but still no luck. The first try I pressed the remote for the garage and my homelink button on the car simulataneously and the light come on solid and then blinks slowly, but never blinks rapidly like the book says. So I reset the homelink by holding the two outer buttons and tried again. No luck. Then I tried the rolling code method. The garage is a Wayne Dalton idrive (2005). When I tried the rolling code, I pressed the programming button on the actuall motor of the garage door lift and it beeped. I went to my car in well under 30 seconds and pressed the homelink button in 2-3 times. Still no luck. Please any help with this would be greatly appreciated. Thanks
Old Jan 31, 2009 | 05:49 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
I have the same problems as you to these days. I did everything as you mentioned but no luck. I have no problem programmed my Slk 230, Clk 430 and CL 55 in the past with the same garage opener.
