tranny please???
Old Jun 12, 2009 | 01:43 AM
05clk500Art's Avatar
95civicsi, 2001 e320, 2001 integra type-r, 2005 clk500
tranny please???
whats up guys??
OK, I know alot of people that have the 03 e/clk (500) have the trans problem with valeo radiator and some with the 04 model.
So0o my qusetion for you guys is that, i have a 05 clk500 with valeo,
do i need to replace it??? or is this a new updated one ?
If i do have to replace it, i know the behr is what every one was getting, but i cant fine any. BUT i found this http://www.importautoparts.com/feed/...s/clk500/2005/ do you guys think it would be any good???
thanks for all the info and help guys!!!!
Old Jun 12, 2009 | 01:44 PM
ZEEK's Avatar
Yo Momma
dude, you think wayyyyyy ahead of time. I never had that problem with my 03 but do it when you have a problem lol, i dont think you will have a problem with it. Use your car but dont abuse your car.
Old Jun 12, 2009 | 02:16 PM
Thanks for the advise man!!! I'm not going to lie, I do "kinda" abuse it!!! Lol.... Its a great fun car to drive. I just wanted to be sure befor any thing happen to my baby.
150-200 is better then 6000-7000
Old Jun 14, 2009 | 05:17 AM
clk_dsl_pwr's Avatar
CLK 30cdi AMG W209, A Lang W168, Impreza Sti GC8
It has nothing to do with abuse.
If you have the valeo radiator you should test your tranny oli asap.
It starts to leak sooner or later.
Then you have to change the radiator, transmission and turbine. It's about 8000usd.
I know, i just did it
Old Jun 14, 2009 | 11:39 AM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
I'm in the exact same predicament, but worse. I have a 2004 CLK500, manufactured in 09/03 (cutoff date for the Service Bulletin) and have the Valeo Radiator. I inspected the unit and I think it has the updated fix, but I still don't trust it. The part number of my Valeo is A203 500 39 03.
I'll probably end up doing what you do 05clk500Art, so let us know where you find the Behr radiator and how much it cost to install. By the way, you have your CF diffuser as well, have you installed it? What kind of exhaust setup do you have?
Old Jun 14, 2009 | 12:06 PM
Star-Garage's Avatar
E55(210) CL600(140) C320(203) E350 Saks 5th ave. add.(211)
The 05 model year does not apply to that bulletin. The replacement for the faulty radiators will be a Valeo with same part # so don't condem yours based on the brand. The bad ones again were on mostly 03 m.y. cars identifiable by the style of crimping along the edges.
Old Jun 15, 2009 | 08:54 AM
humm thanks guy
Old Jun 15, 2009 | 12:28 PM
Supafly's Avatar
I drive the racism out of BadDebt. ;)
okay...so i dont understand why you have to pay so much for another radiator?.... go buy a external B&M oil cooler, and some russel SS braided lines, and reroute that *******.... clean out the resevoir in your radiator and plug it... save your butt 300 dollars and have better cooling efficiency for your tranny.
Old Jun 15, 2009 | 01:21 PM
Nealgobert's Avatar
Rentals
I had the same thought, and tried it immediately after purchasing my car. Would I recommend it now that I tried it? No- unless you're interested in possibly obtaining a $9100 bill to replace everything youre trying to protect. Car lasted just over 1 mile with the cooler. Why? I have no clue as it was a total surprise to me (I have installed coolers on other makes without an issue). Service department could only speculate as could I, but they did say it was a bad idea. All I know is I won't be trying it again. Oh well lesson learned I guess
Old Jun 15, 2009 | 01:41 PM
I might do that, can you please help me fine the part# how many feet for the hose and what about the plugs?? Thanks for the help
Old Jun 15, 2009 | 01:44 PM
O my!!! Hummm now I'm kinda lost. Lol
Old Jun 15, 2009 | 03:18 PM
Nealgobert's Avatar
Rentals
Yeah I know what you mean. Tech said the cooler was wrong type (factory according to him is liquid to liquid cooler not air cooled, meaning factory cooler is submerged in engine coolant), it was placed in wrong position (directly behind grille!) not getting airflow, and was too small (despite being designed for vehicles up to 30000 gvwr, well beyond what our cars weigh). B&M had no explanation, and I never thought in a million years I would lose a transmission like that. Tech said it overheated, but in just over one mile!!!! I couldn't even get it to heat up anything beyond 41c to read the level in the driveway! I think it was a flow restriction somewhere, but where I don't know....I checked everything prior to installation. And now I'll never know as dealer lost all my parts after removing them.
Car went to limp mode almost immediately, and I found metal shavings when I checked it. Prior to the install I flushed the system- old fluid was perfect. I also had it glycol tested and it passed with flying colors.
Trust me if it had not happened to me I would have never believed it was possible. But it did, and now I have a new transmission. Ironically they left the old Valeo radiator insisting I need no worry. But I'm not replacing a tranny again, so I'm still going to have to change the radiator after all that happened. I have heard of others that did an external cooler without issue, but I just wanted to share my experience.
Old Jun 15, 2009 | 03:45 PM
Nealgobert's Avatar
Rentals
Oh and Star-Garage is right; I wouldn't worry about an 05 as the issue was resolved by then. It only applied to vehicles mfg up to 9/03 with a specific Valeo radiator and the 722.6 transmission. An 05 is in the clear and even has a different transmission (722.9).
Old Jun 15, 2009 | 11:22 PM
that you
Old Jun 16, 2009 | 12:31 AM
The cooler problem is only on -03-04, i didn't notice you have an -05.
Don't put an external oil cooler as it will ceep the transmission oil too cool and that is going to be a problem...
Old Jun 16, 2009 | 09:50 AM
thanks you
Old Jun 16, 2009 | 10:18 AM
Supafly's Avatar
thats odd...i would suspect that there was a problem already brewing and that the tech just needed something to blame the problem on.
Theres too many questions to go about it...but i think if you do the research to get the correct cooler with decent quality, and placed in a well thought out location... i really can't see a problem brewing from an A-A cooler...providing the operating temps to be within 160* to 200*....anything above is catostrophic to bearings and seals, anything below and it needs to be driven harder...
Im not saying that you did not do your research, but i think your tech is full of shat, and wanted you to for out 9Gs...
Its too bad your tech tossed all your equipment, otherwise it would be a good way to spot the problem.
Old Jun 16, 2009 | 12:59 PM
Nealgobert's Avatar
Rentals
No problems prior. First thing I did after delivery of the car was verify that the transmission was in as good a shape as it seemed. It ran fine, so I drained the pan and inspected the filter for any signs of failure...the oil was clean. Refilled and drove again...fine. Installed the cooler and drove down the road- limp mode. When I got it home I checked the fluid again and it was saturated with shavings. That's when I knew I would need a new transmission and brought it to the dealer.
It was perfect before and trashed after a mile with the cooler. I don't completely agree with the mercedes tech- the transmission did overheat but I don't think that was the cause of failure. I think it was the result of a lack of flow through the cooler. Now what caused that restriction I'll never know.
BTW sorry for getting off the op's topic
Old Jun 16, 2009 | 03:56 PM
Discgolfer74's Avatar
2003 CLK500
I don't know what you should do, but protecting your "investment" should be priority one.
I just suffered the gycol curse on my 03, even after I asked the stealership to check for it when I got my A Service. They never did, and told me not to worry about it. Repair estimate: $7800!
I just bought that same radiator... still waiting to get installed. I can't say how well it works yet, but I'm in a position where I need to save as much money as I can. Dealer wanted about $500 for their radiator. Also bought a used CL500 transmission with 21000 miles for $1300 (avg price $2600 - $3800).
From my personal experience; "Prevent, Warranty, & Insure"!
Good luck!
(btw, glycol contamination test is $120 - $180)
