1st oil change 6k miles
So my car just hit a little over 6k miles i checked oil level and it's on the lower side of the dipstick so i decided it's time to change the oil...
I was reading the forums but could not find which oil the 5.5L motor takes.
it's 90 degrees outside this week and i was reading there is diff viscosity of oil needs to be used depending on the temperature....
So do i use 0 W 20....?
thank you.
thank you.
Does it says 0W 40 under your hood ? I used this all the time.
https://mbworld.org/forums/c-class-w...ments-usa.html
Andy
Andy
