Mtec HID kit installation problem Help!
Old Sep 22, 2009 | 07:58 PM
TigerJK's Avatar
2013 SL550
Hi guys
I got Mtec HID kit from ebay... and I went to several auto repair
shops around here to install and most have never done this job before..
I know it's not plug & play. It requires wirings and has a big ballast..
Where I can get this job done? Obviously I don't want to do it myself..
Most asked me around 100 bucks for the labor charge.. I thought this job
would be very easy. But it seems not...
Where's the best place to get it done? Where can I find electronic
specialists? Anyone installed with mtec kit?
Please help!
Old Sep 23, 2009 | 12:06 AM
bheng's Avatar
2003 CLK 320
it should be plug and play.
i think for mine, it wasnt mtec but i just had to plug it in where the bulb was and where the outlet looking thing was and it worked. shouldnt be too hard tho. check some youtube videos maybe?
Old Sep 23, 2009 | 01:15 AM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
Mtec kit are plug and play bro, put the bulbs in where your old ones were, the ballast with the kit plugs to your factory harness, the two connect out the ballast connect to the HID bulb. thats it.... you might need a resistor harness so that it throws no error code.
Old Sep 23, 2009 | 02:36 AM
raymond g-'s Avatar
99 E320
a number of established vendors steer clear of thse kit installations because
it's bad for their business. they are not DOT compliant, ergo, less than legal.
not worth the hassle. offshore, aftermarket, unproven parts. if they install
and the kit doesn't work well, the car owner tries to get them to troubleshoot,
or even put the blame on them
Old Sep 23, 2009 | 02:56 AM
TigerJK's Avatar
2013 SL550
Thanks everyone. Major problem is that the kit plugs don't match with factory harness.... I need to cut the harness and connect together..
I'll go to pep boys tomorrow to see what happens.. They told me they can do it.
Old Sep 23, 2009 | 04:21 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
It should be plug-n-play. I think you bought a kit that belong to another models.
Old Sep 23, 2009 | 04:58 AM
AzCamel's Avatar
DONT CUT!! you bought the wrong kit.. if you bought the right kit for the car it will plug in.
Old Sep 23, 2009 | 09:35 AM
TigerJK's Avatar
2013 SL550
I don't think I bought the wrong kit.. I double checked with it and it's definately for W209 and the product says it "REQUIRED WIRINGS FOR W290 CLK CLASS" Well, let me double check today again.
Thanks!
Old Sep 23, 2009 | 11:01 AM
M-bENZ's Avatar
Corrolla
You better not cut the wire.
Andy
Old Sep 23, 2009 | 11:03 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Thanks!
It don't matter what the product or the ebay seller says. You bought the wrong kit. Should've read the forum prior to purchase.
Old Sep 23, 2009 | 03:17 PM
TigerJK's Avatar
2013 SL550
Hey guys, I just went to Pep boys to install it.
The kit is fine. The other guy from repair shop said I got the wrong kit but
Pep guys pluged in and it worked on the driver side. Least that's good.
However, New problem has occured. Light didn't work on the passenger
side. Not even flickering. They checked the strength and switched the
ballast and bulb everything but still nothing, so they believed ballast was
something wrong because it didn't pick up the enough power from
the headlight outlet, I asked for the resistor but they don't carry it. Well, I
believe this mtec doesn't need a resistor to set up. Anyway, they gave up
and tried to put the stock one and it also didn't work!! I was so
surprised and frustrated. So they thought the socket from the headlight
outlet is the main cause. I have no idea at all. What could it be?? I'm
thinking to take this car to dealer soon. Do they install aftermarket HID?
please help me out
guys.
Old Sep 23, 2009 | 03:25 PM
TuneTime's Avatar
Former Vendor
Any AMG Thats Around..
Usually there isin't enough voltage to power up both ballasts at the same time... They suck alot of juice on the first inital startup... Thats why alot of guys have to turn them off and on a few times to have them both come on... Then alot of people have to wire in relays to get the power directly from the battery....
I have used the DDM 35W (low power) Kit in my W202 C and have not had any problems... But in general i do not like doing HID installs, usually its more of a pain then its worth....
Old Sep 23, 2009 | 03:38 PM
TigerJK's Avatar
2013 SL550
I see. My question is how come the stock bulb is not working? This is really painful guys... that power outlet on the passenger side has enough power and still doesn't work at all. Should I plug it and turn on & off repeatedly?
Old Sep 23, 2009 | 03:40 PM
TuneTime's Avatar
Former Vendor
So you have the Stock bulb in place... All the HID stuff is removed.... And the regular bullb still does not work?
Old Sep 23, 2009 | 03:46 PM
TigerJK's Avatar
2013 SL550
Yes. I removed all HID and replaced the stock ones. Same thing happened. light on the driver side is working and the passenger side is not working.
Old Sep 23, 2009 | 04:08 PM
bheng's Avatar
2003 CLK 320
looks like you have a faulty passenger side? time to go to the dealer.
remember to put your stock bulbs back on.
Old Sep 23, 2009 | 04:17 PM
M-bENZ's Avatar
Corrolla
What have you done to it TigerJK ?
Andy
Old Sep 23, 2009 | 05:13 PM
TuneTime's Avatar
Former Vendor
maybe the pin in the bulb socket got pushed out....
Old Sep 23, 2009 | 07:47 PM
TigerJK's Avatar
2013 SL550
I have made an appointment with dealer. I hope it's not big issue. I'm sure they can fix it. HOWEVER, WHAT SHOULD I DO WITH THESE MTEC KIT????
I know they don't install aftermarket HID for me. What would you do with it? After fixing the stock light, should I try to reinstall mtec again? What if it's not working again?
Tell me what to do.....
