19" BRABUS Monoblock VI Double Spoke Design
Hey Guys,
For those who had Brabus wheels on there CLK. I was thinking of getting a used set (19” BRABUS Monoblock VI Double Spoke Design)
Front Wheels: 8.5JX19, offset 37mm, tire (235/35ZR19)
Rear Wheels: 9.5JX19, offset 35mm, tire (265/30ZR19)
Will these work on our cars? The seller said they were off a W209 CLK. But I was browsing through Brabus website the measurements don't seem to match. And will I need original Brabus lug bolts or can I use my OEM lug bolts?
Thank you Guys for all the help.
1 Post
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
I can't vouch for the real thing, but have a set of replicas than only differ in the front offset by 5mm. Mine are +32 and run within just a few mm from the strut. I run the exact tire setup with no issues. My rep's took a 27mm shank lug compared to the OEM 39mm shank. RAD USA direct is a great place for bolts. Hope this helped some, Mike
1 Post
I didn't see any on mine, but there again I knew what I was buying. I have heard that some OEM replicas have a designated marking. M
2018 E43 | 2017 GLS450 | 2004 CLK 500
You should have no problems makeing the wheels work. The Brabus wheels uses different spacers for each applicaiton. If you need the correct sapcer for your car contact them. One of the guys on here with a baclk 55 has Brabus 19's - you should ask him what his offset is.
I remmebr thinking the Brabus catalog wheels offsets for the w09 weren't correct.
i have a set of brand new 5mm spacers you can use for the front to bring it down to 32 like the poster above. PM me if your instrested in them.
