HELP...Parking Lamp does not turn OFF?
CLK 500
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Recently, my passenger side parking light remains ON at all times. I had to remove the bulb so my battery doesn't get drained. Has this happened to anyone? If so, what's the solution?
Check your relay's. i am having problems with my lights too.
A friend recommended to check that and after lots of research i believe that might be the problem.
I will do a check tomorrow and see what is going on!!
Good luck
Good luck
I am actually having this exact same problem. Even with the car off and the doors locked, my drivers side parking lamp stays on. My headlights are on A and I've tried putting it in 0 and still it stays on.
Ive pulled the bulb for now but now I get the stupid parking lamp malfunction warning every time I start the car.
Any thoughts?
Any thoughts?
MBworld Guru
First, electrical gremlins are often cause by voltage problems. Check your battery voltage - at least 12.4v at rest, no less than 11v during start, and somewhere close to 14v at idle. These lights are controlled by the front SAM. Here are some fuses to check - 62, 63, 50, 51, replay P and relay K. I doubt they are blow or not working as they also control other systems, but a dirty contact can cause gremlins.
