209 Cab Window Rattle
Old Nov 2, 2009 | 12:54 AM
Powertwang's Avatar
SLK 320
The driver's side window(s) on my car, which has less than 17,000 miles on it, is/are making a bit of a ruckus when I go over fairly small bumps. I'm not sure whether it's the front or rear window (or both) making the noise. Is this a common problem? Any suggestions for a fix? Tia.
Old Nov 3, 2009 | 08:10 PM
Knight 43's Avatar
2007 CLK 550
Welcome to the world of Cabs and the window rattle. First off, check to see if your windows are in synch with each other. Shut your door or roll your windows up. Check that the back window lines up slightly behind the door window with the rubber seal. If so, open your door and get underneath and you will see 4 rubber plugs. Remove the plugs and check to see if you have nuts missing from any of the window rails. Hopefully you will have a nut missing and your rail has shifted a little out of adjustment. Attach a new nut or find the one missing in the door " good luck" . I had a rattle sound coming from mine as well and just played with the adjustment more and more until I finally got the rattle eliminated. I hope this helped somewhat, good luck with the rattle reduction.
