transmission not working..... HELP!
Old Nov 14, 2009 | 07:14 PM
JALE's Avatar
2003 CLK 500
heres the rundown.
car: 2003 clk500
issue: glycol contamination
car ran perfectly but i had issue with glycol on the car. purchased a new behr radiator and swap it out. the cars cooling issue is perfect.
drained the transmission and dropped the pan. replaced tranny filter, and replaced fluid with mb 722.6 specific fluid. added 5 quarts.
car cranks fine and sounds really good, but now the transmission doesnt work. i put it into gear, but the car doesnt move. its like its in neutral or something. plus, i cant change gears manually (drive + left or right) as it doenst show on the dash indicator. another thing is the auto-matic hold no longer works.
anyone have any ideas?
Old Nov 14, 2009 | 08:55 PM
JALE's Avatar
2003 CLK 500
transmission is very sluggish, but the car moves. what could be the cause?
Old Nov 14, 2009 | 10:11 PM
Flame3g's Avatar
CLK500 SPORT
when i got my tranny service the MB tech told me the process and it was long and i didn't have the equipment that they had, so i would probably take it to an independent or to the dealer and have them reservice it or look at it. one thing he told me was they have to hook it up to a machine and pump fluid thru it and Ect.....
Old Nov 14, 2009 | 11:41 PM
mk4mike's Avatar
Sold - CLK500
im no mechanic, but honestly i think that tranny is gone.. once its contaminated..
i just had my tranny and axles replaced under warranty.. the car had 50k miles
Old Nov 15, 2009 | 11:48 AM
rsatmans's Avatar
None
My bet is the torque converter. In the the MB TSB they usually replace that before the transmission. About how much was it to replace the radiator and do the fluid swap with labor?
Old Nov 16, 2009 | 10:09 AM
J Lucas's Avatar
I had that exact same problem on my 209 55
Solution:
New Torque Converter , New Radiator, New Transmission and every link in between was replaced before hand trying to save a buck a two.
Cost to me 0. Cost to Mercedes. $11,000 +
Old Nov 16, 2009 | 11:41 AM
JALE's Avatar
2003 CLK 500
unfortunately my car is no longer in warranty. the thing is, before i flushed the transmission the car drove fine.
Old Nov 16, 2009 | 03:07 PM
Moedy's Avatar
'05 CLK55, '04 CLK320
damn that really sucks for all of you, if it is so common how is it not a recall??
Old Nov 16, 2009 | 05:54 PM
Rashman's Avatar
Mercedes-Benz CLK63 AMG Coupe
[quote=Flame3g;3809808]...when i got my tranny service the MB tech told me the process and it was long ....[quote]
I think you're right.
I will be having my tranny fluid changed soon (I like to change fluids often) and spoke to my guy at MB.
He lives close to me and I asked if it was something he could do on my driveway.
He said NO.
He says that the process is alot more delicate that an oil change.
From what I remember, he said that the car has to be put in the air, at the correct angle, and the fluid is changed in stages.
Maybe the car could be sorted by asking MB to do another tranny fluid change.
I'm hoping there hasn't been much damage.
Old Nov 25, 2009 | 03:15 AM
clk_dsl_pwr's Avatar
CLK 30cdi AMG W209, A Lang W168, Impreza Sti GC8
When you have clycol in the tranny it starts to slip. That causes a faultcode in the ETC. You have to reset it with MB Star. Otherwise the car doesn't move.
But it might be that your tranny has already gone...
And remember to change the oil atleast twice becouse half of the oil remains in the turbine!
