CLK Washer pump relay or fuse
200CLK Komp w209 2004
Hi - newbie here - hope someone can help with this.
I have lost power to my windscreen washer pump. I know pump is OK because I have swapped the connector over from the headlamp pump and now wash windows by pressing headlamp wash button.
Have checked voltage at connector and nothing when button on end of stalk is pressed. Fuse info leaflet says "Electronic" so guess it must be a relay but where and what type?
It seems to have come about because the end of the washer hose next to the resorvoir looks to have been damaged somehow (it's down in front of the wheelarch cover access door so can't see how) The end of it has broke away allowing washer fluid to leak but also revealed bare wires from what I am guessing is a heating system to stop the hose freezing. Could this have shorted out a relay? Have posted this is general technical as well.
Any help appreciated
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Found some info which points to it being one of the 8 relays in the fuse block below the windscreen scuttle in the engine bay.
There are 3 small black relays ref. B2002 542 119, 2 yellow ones ref. A002 542 1419, 2 larger black ones ref. A002 542 1319 and one grey relay ref. A002 542 2619.
Anyone know which one would be for the windscreen washer pump - save me using trial and error by removing each one and seeing what stops working
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
