!!!!!!!HELP!!!!!! Brake Rotor Removel
Old Feb 13, 2010 | 03:20 PM
Flame3g's Avatar
CLK500 SPORT
hey guys can't get my front brake rotor off....took the caliper off and removed the screw from the rotor but the rotor will not move....am i missing something...i have been kicking it to see if its just rust but no luck
Old Feb 13, 2010 | 03:22 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
LOL @
Wish I could help! Would be good to know!
Old Feb 13, 2010 | 06:04 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Flame3g,
Use the "search" feature PLEASE !!!!!! I and many others from other forum posted it before. All you need is can of corrosion eater, rubber hammer and a couple beers for the job. Btw, the rear is even hard because of the parking brake.
Old Feb 13, 2010 | 06:56 PM
Flame3g's Avatar
CLK500 SPORT
hey man i did search im not new to the forum.....but thanks for the reply...all is good im finishing up now.....
Old Feb 13, 2010 | 08:24 PM
bheng's Avatar
2003 CLK 320
how did you end up taking it off?
will be doing rears soon so anything to look out for?
Old Feb 13, 2010 | 08:41 PM
Flame3g's Avatar
CLK500 SPORT
didn't do the rears yet wanted to try out these new rotors first......i will probably let sonic ms do the rears when they put my springs and stuff on.....mine were rusted on pretty good just make sure u get some wd-40 and a good rubber mallet
Old Feb 13, 2010 | 08:54 PM
Klinh's Avatar
didn't do the rears yet wanted to try out these new rotors first......i will probably let sonic ms do the rears when they put my springs and stuff on.....mine were rusted on pretty good just make sure u got some wd-40 and a good rubber mallet
The rust build up is normal. Get one of those rust penetration can from Autozone work best.
Old Feb 13, 2010 | 10:33 PM
rennwerkes's Avatar
2001 E55, 2002 ML55, 2002 SL500, 2003 CLK55
Sometimes nothing will work other than a good whack from a metal mallet.
No waiting and it'll come off after a couple of good whacks.
Remember to keep the retaining screw on but loose so that it will allow the rotor to be loosened but not enough that the rotor will fall off.
Old Feb 13, 2010 | 11:20 PM
Klinh's Avatar
thanks guys....bought some PB Stuff from autozone....sprayed it on waited like five minutes and smacked the **** out of it with a rubber mallet and BBBAAAMMM.....finishing the other side now thanks for all the help...love this forum
Old Feb 14, 2010 | 03:13 AM
bheng's Avatar
2003 CLK 320
lol well then i guess ill try that when i change my rotors soon.
Old Feb 16, 2010 | 12:33 AM
SZMB's Avatar
2004 E500 CLK320
Just shoot some WD40 and use a big metal hammer hitting the rotor hard -- just bang the heck out of it, it will come off. You don't plan to use the old rotor anyway.
Old Feb 16, 2010 | 01:21 AM
dhctrading's Avatar
CLK500
rotor
Get a rubber mallet and smack hard all around the rotor and it will come lose..just built up with rust
Old Feb 16, 2010 | 11:43 AM
astropat's Avatar
CLK 320
Wow... is it really that easy to replace the rotors on the front? Just need WD-40 and a rubber mallet? How long did it take to replace the fronts.
Old Feb 16, 2010 | 05:18 PM
Flame3g's Avatar
CLK500 SPORT
well once i got the first side off the other took about 10min...i had to eat lunch while the rust stuff worked
Old Feb 17, 2010 | 09:53 AM
2150john's Avatar
E 450 4matic cab MY22
I have never done the rotors on a CLK. However, I've removed them from many other cars. Penetrating oil and a BFH has always done the trick! lol.
Old Feb 17, 2010 | 06:26 PM
rennwerkes's Avatar
Folks, if you have a BFH, penetrating oil really isn't necessary. The shock of the hammer will brake loose the rotor. I've done well over 30-50 brake jobs on BMW and Mercedes and never used penetrating oil and all the rotors came loose nicely.
What I do use when reinstalling the rotors is a thin film of anti-seize paste before reinstalling the new rotor.
Old Feb 17, 2010 | 07:36 PM
MBtech1098's Avatar
10 speed bicycle
Originally Posted by rennwerkes
Folks, if you have a BFH, penetrating oil really isn't necessary...
...What I do use when reinstalling the rotors is a thin film of anti-seize paste before reinstalling the new rotor.
+1
I have done countless brake jobs, as well as seen many other professionals do countless brake jobs. This is how it is always done.
BTW, Nice MV!
Old Feb 17, 2010 | 07:47 PM
rennwerkes's Avatar
Originally Posted by MBtech1098
+1
BTW, Nice MV!
LOL!
Nice "Husky"!!!
Old Feb 17, 2010 | 08:15 PM
MBtech1098's Avatar
10 speed bicycle
Of all my bikes, she is the most fun to ride!
Old Feb 17, 2010 | 10:51 PM
Klinh's Avatar
Yes, you've done it many times so you know it will come out with a couple hard shock of the hammer. You have to understand that most of the people here, it their first time of doing it so they're afraid to knock it hard enough to loose it. As for the anti-seize paste, same goes with the spark plugs and the grease/lube for the plugs boots.
Old Feb 18, 2010 | 12:56 AM
rennwerkes's Avatar
Klinh, I hear you.
But that's what I'm trying to get across, don't be afraid to knock away. Many times on these forums, a first timer will be nice enough to chime in but offer either erroneous info or info that's not completely correct. I'm just hoping to steer folks in the correct direction.
One more thing, a rubber mallet may prove frustrating if the rotor is really rusted on.
Old Feb 18, 2010 | 01:07 AM
Klinh's Avatar
Klinh, I hear you.
I still remember my first time doing it. I has my front end on the jack stand. I was afraid to hit that sucker any harder because the car might just fall off the stand. . Plus, at the shop where the car is on the lift, it alot easier to give it a full wack when you standing. About 8 months ago, I did a complete brake jobs front and rear on my 2001 clk 430. I was afraid to hit the rear rotors at full blow because i was afraid the emergency brake spring load might pop out inside. So I decided just to pry it out and it work.
Old Feb 18, 2010 | 02:12 AM
rennwerkes's Avatar
Nah, there's no way your emergency brake springs would pop just by hitting the rotor's edge. I am assuming you released the emergency brake!
Just remember to rotate the rotor gradually as you hit it.
Old Feb 18, 2010 | 02:31 AM
Klinh's Avatar
I am assuming you released the emergency brake!.
Old Feb 18, 2010 | 04:14 AM
WPOZZZ's Avatar
W211 E55, 911 turbo, 911sc, RX330
Exactly! No real need to worry about the rotor as you are replacing it anyway. A rubber mallet is very frustrating as the rubber will absorb a lot of the impact.
