I installed D1S HID 6000K low beam to match my 6000k HID foglight today.
Looking for a little help here. I got my HID kit for my fogs, and was wondering what you did with the second set of wires that are running through the rubber plug. Did you just clip them off?
Need some help here, as I don't want to eff anything up.
The attached are the 6000K bulb for my Bi-X replacement.
Questions:
1) The plastic cover over the bulb -- is that just discarded. Likewise, for the H11 install for my fogs, do I need to get rid of those covers?
2) Does anyone know what the little black gasket-type thing taped to the bottom is for?
Thanks guys.
Questions:
Thanks guys.
The plastic cover I guess you can throw it out as it's just preventing the bulb from being damaged. The black gasket thing should go around the base of the bulb. I believe it helps lock the bulb in place though I might be wrong.
On mine D1S HID bulbs, you don't need the black ring that came with the bulbs. Just transfer the mechanism locking ring from your old bulb to the new bulb. Make sure the locking ring is EXACT in the same position when transfer over the new bulb. Just line up the 2 bulbs before you remove the locking ring from your old one.
If you read my pass post, you would know it an H7 not H11. And even if you got the H7, you would still wouldn't know how to lock the bulb into the housing. So find my past post with pictures of my own design "lock ring".
It is plug-n-play for those foglight housing that use the locking clip. Nothing is difficult for me when it come to modding car.
