Removing Switch Row
Old Mar 26, 2010 | 12:14 PM
thrilos81's Avatar
2007 Mercedes CLK63 AMG
Removing Switch Row
Hi,
I am trying to install a comand system on my facelifted w209. The part where I am having difficulties is removing the switch row to gain acces to the upper two T20 torx screws that hold the audio 20 system in place. How do i remove the switch row panel (heated seats, sunblind, hazard lights, etc)??? The only way I see is a little space when I open the cupholder. How do i proceed from there?
Thanks in advance
Old Mar 26, 2010 | 12:50 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
http://www.mymbonline.com/forum/viewtopic.php?t=3331
Old Mar 26, 2010 | 04:01 PM
M-bENZ's Avatar
Corrolla
Your is 03 or 05. They are different.
Andy
Old Mar 26, 2010 | 04:07 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Facelifted is 05+ right?
Old Mar 26, 2010 | 07:44 PM
thrilos81's Avatar
its a facelift with the audio 20. I ve seen that post for the w203 before. I've done the bottom half, however the top, where the switchrow is located, is different for the clk. That's the part i cant figure out. how to remove the clk's switchrow.
Old Mar 27, 2010 | 02:13 PM
thegecko1's Avatar
Clk 320
It is just clipped on. There are two clips in the center by the flasher button then one clip on each end of the wood trim. You might be able to just pull it out if you open up the cupholder and pry it off from there.
