CRANKSHAFT POSITION SENSOR LOCATION???
Old Apr 8, 2010 | 02:09 PM
wazv6's Avatar
'14 E550
Hey MB'ers. I recently found out that I have to replace my crankshaft position sensor due to my car throwing the P0335 code. I've searched and found out its a pretty easy procedure that I can do. Only prob is that I have no idea where it's located in our engine bays . Any help is greatly appreciated. Thanks Fellas.
Old Apr 8, 2010 | 02:19 PM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
when i did mine it only took me 5 minutes to find a write up with pictures.
about 6 inches down
Old Apr 8, 2010 | 02:28 PM
wazv6's Avatar
'14 E550
about 6 inches down
Thanks Buddy
Old Apr 8, 2010 | 09:16 PM
AMGSpartan's Avatar
2008 GL320 CDI, 2007 E320, 2005 Passat TDI
Hey Waz,
When I replace mine a couple weeks ago I used a 1/4 inch socket (1/4 inch drive with approx 14" extension). The bolt is actually requires a T-8 (Torx 8) SOCKET which I'd never seen until I had removed the bolt. I had Torx drivers (all male) which are ratchet driven but not "sockets." Anyway, if you lack the Torx socket like I did, a 1/4" socket works well.
/Sparticus
Old Apr 8, 2010 | 10:48 PM
wazv6's Avatar
'14 E550
Originally Posted by AMGSpartan
Hey Waz,
/Sparticus
Thanks for the heads up AMGSpartan. I don't have any torx sockets and was actually going to purchase the T-8 but i'll try the 1/4 inch and hopefully it works out. If not im off to the local hardware store lol.
Old Apr 8, 2010 | 11:47 PM
Supafly's Avatar
I drive the racism out of BadDebt. ;)
its kinda hard to explain but i will try to explain my best,
-remove your airbox
-look on the drivers side, behind the valve cover there is a 1 black wire at the bottom just above the tranny, its kinda cramp in that area, so a mirror is handy...grab it and trace it to the back of the motor...you wil need a socket, a 6" extention and a 1/4 ratchet, i forgot what size the torx socket size is...
-To make the DIY easier, i temp-disconnect the fuel line, and removed the driverside valve cover so i can access the plug. Its deep in there so its gonna need lots of patients and small hands.
- If you remove the fuel line and the valve cover, this DIY should take you about 1/2 hr.....if you do not remove the items, it will take you a few hrs plus shredded arms..haha
Old Apr 9, 2010 | 12:19 PM
AMGSpartan's Avatar
-remove your airbox
I DID remove the airbox. I did not disconnect the fuel line. On my car there is a sort of 'boot' over the CPS that made it hard to see. I could feel it...so I pulled the 'boot' thingy up the wire and that made accessing the plug and disconnecting it from the CPS easier. The boot was just some fibrous stuff wrapped around the wire bundle supplying the CPS. You'll see when you start looking around.
/Spart
Old Apr 9, 2010 | 04:10 PM
wazv6's Avatar
'14 E550
Thanks for the help Spart and Supafly. I should be receiving the CPS today and start to work on it asap.
Old Apr 9, 2010 | 10:56 PM
wazv6's Avatar
'14 E550
Well I got my CPS sensor and im having a tough time getting the defective CPS out. It's such a pain in the *** to get back there and unscrew the damn bolt. Any ideas on how to make the job easier ??
Old Apr 11, 2010 | 05:47 PM
AMGSpartan's Avatar
Hey, I feel for you. It took me a coupla tries to get mine out.
What I did...
-cold engine
-removed airbox
-padded the top of the engine with a movers pad/blanket
-got several 1/4 inch ratchet extensions within reach
-climbed on top of engine so I could put both arms down into area where CPS lives. Right & left hands touching CPS...working by 'feel' (the traditional "bimanual technique")
-for my engine it took a 2 extensions to give the right length to let me put the ratchet on and have room to swing the handle. One guy posted on another thread he used something like a 14 or 16 inch extension but that would NOT have worked for my situation. I think I cobbled a 4 + 6 inch extensions. Getting the 1/4 inch socket to seat onto the bolt's head is the trick.
-having a magnet-on-a-stick and a mirror-on-a-stick help for when you drop things (sockets, extensions, BOLTS - YIKES) or want a better view of the terrain.
Since doing my CPS I've seen these cheesy little ratchet handles that are basically a nurled *** with a ratcheting mechanism in the center. They sell them at Tractor supply, Northern Tool, and (gasp) Harbor Freight. Picture a 2.5 inch dia wheel or knob with a 1/4 inch ratchet drive in the center. When I saw that I pictured being able to stick a short (like 2 inch) extension on there and using it to turn the CPS bolt. I bought one and will use it "next time." Anyway this is the gimmicky little tool they sell near the end of the isle or by the check out. I'm starting to think it may be VERY useful when you have small bolts in places with NO ROOM to swing a regular ratchet handle.
It may also help to use the right words as you struggle with this &%@#ing job
/S
Old Apr 12, 2010 | 09:08 PM
wazv6's Avatar
'14 E550
What I did...
-cold engine
-removed airbox
/S
Thanks for the detailed info SPART. Well i got the job done and boy was it a pain in my ***. It was located in such a cramped area. but with the 6' extention and MUCH MUCH patience finally got the CPS out and the new one in. My car is back to normal now. Thanks for all the help guys.
Old Aug 6, 2014 | 01:39 PM
MelVelasquez's Avatar
CLK500
Crankshaft Position Sensor Dealer vs Auto-part purchase
Hello All,
I have a MB CLK500 and my crankshaft position sensor went bad now I called different dealers and all of them have different prices, the cheapest one I found was $150 dollars. Now I called also a few auto-parts around the area and the have a crankshaft position sensor for a CLK500 for the amount of 65 dollars. now my question is the following: Do I have to buy the crankshaft sensor via my VIN number? I really don't want to pay a lot of money for a part which I can buy cheaper if its the same part at an auto-part.
Best,
Mel
Old Aug 6, 2014 | 11:22 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Try parts.com - they might be less than the dealer, but they ship OEM parts from dealers. If nothing else, take the parts.com price to your local dealer's parts counter and ask them to match it. I would not buy a generic Chinese part.
Old Oct 31, 2014 | 07:00 PM
Wodeshed's Avatar
Current: 2020 E450 with self-driving capability
Thanks for all the tips here. I'm reading both the sedan and coupe forums for advice. My biggest problem has been finding the damn thing, so I thought I'd repeat something posted on the w203 forum. If you, like I did, take out the MAF sensor and housing, you'll see that there's an electrical connector directly below that housing. That is NOT the CPS. Look lower and to the right and there it is.
I've got my old one out but dropped the d*mn screw on the new one, so I'll wait til the am to go find the thing.
Old Nov 2, 2014 | 02:53 AM
ambit's Avatar
09 CLK550
Lol, I hate dropping screws. Even worse is when they don't fall out the bottom. This tool has been an awesome addition http://www.harborfreight.com/15-lb-c...ool-95933.html
I am still missing a T30 torx bit somewhere in the engine bay. Never found it.
Old Nov 6, 2014 | 06:13 PM
Wodeshed's Avatar
I found it after about two hours of looking. It had ricocheted behind the heat shield alongside the left front wheel, and somehow managed to be WAY up high (from my perspective under the car). I was terrified that it had somehow dropped into the hole for the CPS, so it was quite a relief to find it.
Old Nov 6, 2014 | 06:17 PM
Wodeshed's Avatar
Also, by the way, I had read somewhere a suggestion to put in the CPS and screw together (at the same time). I was trying that method, which I decided was impossible. What ultimately DID work was to tape the screw head to the torx bit. I also ended up taping all of the extensions/universal joint together as well, because they kept coming apart while I was fishing the contraption into position.
Old Nov 6, 2014 | 10:33 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I use Scotch two-sided tape to hold screws onto driver bits. I've even heard of others usin a drop of Super Glue.
Old Feb 28, 2016 | 01:48 PM
dalecan's Avatar
2005 CLK 320
Kudo to those that did this in 30 mins, it took me hours. In the end I had to remove the valve cover box to get access. Surprisingly I had no issues with putting it back in. This is a real pain in the *** job.
Old Dec 28, 2018 | 11:15 PM
gardenmaster's Avatar
2011 C300 4matic
Stuck removing crank position sensor 2011 C300 4matic
I read all the DIY's, and tried to remove the crank position sensor. The hoses are a little different on my 2011 C300 4matic as compared to pictures.
Its very difficult to remove the connector let alone get a E8 torx socket on the bolt. is it actually e8 or e10?
The driver side valve cover looks much longer on my engine perhaps because of the mfg date 02/11 or that its a Canadian car?
Would you recommend removing the valve cover to give me access? Will that large overhanging section come off with the valve cover - its hard to see if its worth it to remove.
Any tips are appreciated. I have a crank no start situation and need help! thx
Old Dec 29, 2018 | 02:23 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You're in the wrong forum. You have a W204. But you have an M272 engine and the CPS is about the same job on it as what is being discussed. However, I would NOT remove the valve cover on your engine! It's a much more involved job on the M272 engine.
Old Dec 29, 2018 | 02:27 PM
2011 C300 4matic
Rudeney. Agreed, this thread was the closest match to my nightmare problem removing the crank position sensor on the W204, after days of searching globally.
I find the material on this forum is very high quality, much better than some of the youtube videos on this subject lacking details.
Ok, so I should not remove the valve cover - thanks for the feedback. Any other suggestions are very welcome.
Old Dec 29, 2018 | 03:18 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Remove the engine cover and MAF sensor for netter access to the CPS. Honestly, replacing it is almost more by feel than sight.
Old Dec 29, 2018 | 05:59 PM
2011 C300 4matic
Rodney: Yes the MAF and right angle boot and connected hoses were already removed. The problem I see (and feel) is the crankshaft position sensor appears to be fastened with a torx screw not a torx bolt. i.e. the materials I read said I would need an E8 torx (female) socket, and I am surprised now I need a torx bit. It is opposite.
Not sure which size bit I need as I barely can get my hand down along the firewall on the driver's side to get a solid fit and not strip the screw head. Maybe that firewall/baffle section can be removed?
Old Dec 29, 2018 | 10:21 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Just to make sure you are looking at the correct part:
