Tire size question!!!
Old Apr 26, 2010 | 01:44 AM
gang1126's Avatar
I am abuot to buy rims from the classified list that are 19x8.5 35 F, 19x9.5 35R.
He has 235 F 275 R. My car(03 CLk320) is lowered with H&R spring.
No spacer at all for now.
What do I need to do make those tires to fit on my car?
guess 275 is bit wider but I remember someone does have 275 on their rears.
Anyone tells me what do I need to do.
Thank you very much.
I appreciate all the helps.~
Old Apr 26, 2010 | 07:22 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
A few people here have 275 in the rear. If you do a search for 275 it should turn up a few threads. The most common is 265 but you should be ok
Old Apr 26, 2010 | 08:54 AM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
i run 275's and lowered quite a bit. you will need to do some fender work for them not to rub. i'm usually okay when nobody rides in the back seat but if you hit a dip the rear will eat up the tires. i'll see if i can post pics later.
Old Apr 26, 2010 | 11:26 AM
gang1126's Avatar
Thanks guys!!
