Instrument panel randomly shut off W209 CLK500 Conv
Old May 27, 2010 | 09:54 AM
rigal53's Avatar
2000 CLK 320
2005 CLK 500 Convertible with 115k miles.
One of my light bulbs (the one that stays lit at night after turning of the car) burned out and I replaced it with a similar looking bulb before going to work.
On my way to work as I’m driving all of a sudden my instrument cluster shut off (the outside temperature and odometer still displayed but was not updating the miles driven). Also my radio shut off but I was able to turn it back on. I also heard the fan (believe it’s the radiator fan) working really hard since there was a lot of noise coming from the engine. I shut of the car and restarted and everything was back to normal.
On the way back from work the same thing happened but the car did not start right away. The key would not want to turn as if there wasn’t any electrical power at all. It eventually started on the 3rd or 4th try.
I came home and removed the light bulb I installed. The next day (day 2) the car worked without and problems.
Today (day 3) I took the light bulb from the good headlight and placed it in the burned out headlight and it worked. I also took the spare light bulb that I had previously tried to install to see if it would work one more time but it did not and I took it out. On my way to work the same thing happened as on the day 1, but this time it happened 2 times and when I arrived at work and restarted the car the check engine light came one.
I must also mention that for a while my info center on the instrument cluster has been displaying that I have several malfunctions associated with lights being either out or working when they are not supposed. I visually inspect it they all work fine, but it keeps telling me side markers lights are out or that the backup light is on when in actuality the side marker lights are on and the reverse light is not on.
Does anyone know what could be causing this?
Old May 27, 2010 | 04:18 PM
rigal53's Avatar
2000 CLK 320
I went to Advance Auto Parts to get the OBD II done and the code "P0600 Serial Comm Link" came up. Does anyone know what this is cause by?
Old May 28, 2010 | 12:26 AM
fusion2007's Avatar
CLS 63 S AMG , s500,clk550
there was a recall for instrument clusters awhile back. with the same issue ur having i think..
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
