2003 clk320 hard start
Old Jul 25, 2010 | 11:58 PM
IownZu's Avatar
clk 320
I have a 2003 clk 320 hard start. sometimes starts after 2 trys , sometime 10 trys. it cranks fine. and had a brand new crank sensor put in, with a new battery. I did an experiment , it starts if I let the system PRIME. would that be a bad fuel pump or a bad fuel acculator? Thanks for your help in advance
Old Jul 26, 2010 | 01:42 AM
Supafly's Avatar
I drive the racism out of BadDebt. ;)
try bad fuel filter....causes a lot of problems (eletrical etc)
cheap fix...
Old Jul 26, 2010 | 09:14 AM
hkim201's Avatar
02 CLK320
i once had similar problem with my car, and it got worse at the end so I had to pull it to nearest garage. Problem found out to be one of those sensors that picks up signal from crank. It wasnt a major prob tho jst changed the sensor and it works perfectly fine!!
