Interior light
if thats the case, ill just skip the cold air intake for now and do the other mods
As for the front turn signal does it accept led's or will it throw a code or not work properly? Also, what about the reverse lights will it accept led's or throw a code/ not work at all?....these should all have resistors too, will that help?
Lastly, for the low beam, high beam and fog light bulbs they won't accept led's at all?....not even with resistors?
Thanks for any help...
Angelo
As far as mirror turn signals i have never seen that before being done... Those are already LED's
Fog lights i have tried but failed so i went with HID's
Low beam? Dont you already have that HID (sig)
Reverse lights would prob be same as fogs also the high beam. I remember Dyno here tried that but it didnt work either...
As for my headlights they're actually bulbs, but I found this company that has extremely bright bulbs that are reliable too...
I don't know if Dyno tried his low beams, reverse lights, fogs, etc. with resistors or if he just used regular led's...i really want to change the reverse lights...have done it on previous cars...looks great and how often am I in reverse?...haha...
Angelo
Red side mirrors would actually be GREAT i never thought of that. let us know if you find anything
As for the reverse lights I could probably find some with resistors already in them so I should be able to do that.
What about the front turn signal you think that'll need resistors?...
A great air intake system might reward you with 5hp, nothing whatsoever in regards to 1/4 mile time reduction. A E55K setup is a nice add on, beyond that, no real/actual worthwile gains - look at Klinhs numbers for proof. I'll be doing the same in a few months.
http://store.ijdmtoy.com/Mercedes-Benz-W209-CLK-SMD-LED-Car-Interior-Lights-p/pkg_euro_smd_25.htm
I think they'll look even better once I get the ext lighting the way I want it...
