Installing sub and amp on clk350
Old Jan 14, 2011 | 12:59 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Originally Posted by palmajh5c
I already have the sub, amp, enclosure, and wiring kit. I took it to a local audio shop and they wanted $600 to install it all. I know this can't be right. How much should installation be?
Don't know how much it should be, but $600 doesn't sound that bad.
astropat's Avatar
CLK 320
Originally Posted by badblackbenz550
Tell em it's a CLK350 you not BALLING.
Old Jan 14, 2011 | 03:16 PM
M-bENZ's Avatar
Corrolla
I got quote of $75 for installation on my 500 and thats it ....$600 ? Did you tell them they going to work on Ferrari ?
Andy
Old Jan 14, 2011 | 03:20 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
lol
badblackbenz550's Avatar
benzo larenzo
Andy
+ 1 they think he got a benz there fore he is brainless and whipes his *** with money.
Old Jan 14, 2011 | 11:38 PM
midnight AMG's Avatar
CLK 550
just a point of reference..
i got a brand new rockford fosgate T1 sub 12", rockford fosgate 500x1 POWER amp nice ported box, dedicated sub switch, 4 gauge power wire
for $600.00 installed
Old Jan 14, 2011 | 11:41 PM
  #32
Clkboi's Avatar
CLS550 4Matic
Pic?
Was this at Best buy?
Old Jan 15, 2011 | 02:37 PM
  #33
palmajh5c's Avatar
c300
If the $600 included the sub and amp that wud make sense, but $600 for installation only doesn't sound right.
Old Jan 26, 2012 | 06:44 AM
  #34
gcoutinho's Avatar
CLK 200 Kompressor
Originally Posted by DisplacedTexan
I ran the Power from the battery. This was the longest part of the install since I really had to make myself cut the hole in the rubber panel for the wiring through the firewall.
Hope this helps.
Can you share a picture of this?
I am trying to pass a power cable to the amplifier, but having problems finding the way to fit the cable.
I have a clk cabrio and i am upgrading the stock stereo. The headunit is now an alpine, but i dont have any bass. The solution is installing one Rockford Fosgate Amp with a SUB in the trunk.
PS: The cabrio trunk is "sealed" from the interior of the car, adding the subwoofer to the trunk is possible to ear it?! uhmmm
Thanks in advance
Old Jan 26, 2012 | 03:39 PM
  #35
grech's Avatar
Mercedes CLK280 2007
Thanks in advance
Here is where you're battery is, under the cabin filter:
Once you take out the battery, you're gonna see the black rubber plate on the bottom left, where you see the red amplifier wire going into the cabin.
Here's a close up:
Like one of the thread posters said, you just need to drill the holes in the rubber and run the wires through it, and put it back in place.
Old Jan 26, 2012 | 06:45 PM
  #36
Jamesbbh's Avatar
2006 Facelift CLK500 Cab-
I ran the wires down all of the factory tunnels Installing sub and amp on clk350-carjeep016-2.jpg
Then pulled this out
of here
Used a little of this= no drilling required for a 2G wire
Old Jan 26, 2012 | 08:23 PM
  #37
M-bENZ's Avatar
Corrolla
I used Jergens instead of vaseline LOL....works great. You gotta use that man , make the job way easier
Jamesbbh,
How did you tune your amp ? what would be the right set up ? The way i have it right now not very happy with it. I have an Alpine 500 watts Mono and a single 12" JL sub.
Old Jan 27, 2012 | 04:22 AM
  #38
gcoutinho's Avatar
CLK 200 Kompressor
Originally Posted by Jamesbbh
Nice
Thats what i was looking for. My only fear is if the sub it will be audible in the trunk. I have the complete audio system, head unit, sub and amplifieres to movo into the CLK. Cabrio are all PITA to get cables into the trunk.
I have this two to fit into the trunk.
One of the most good combination for me. Focal produce very good equipment.
Old Jan 28, 2012 | 01:59 AM
  #39
Jamesbbh's Avatar
Jamesbbh,
Nice
M-Benz- what exactly do you mean? Is it too loud? or not loud enough? I have a 300W RE audio amp bridged to a rockford 10" and it sounds great. I just turned a song with a lot of bass up and then adjusted the gain back down to where it's not overbearing.
gcoutinho, yes it was a bit*h to get the wires back there but after some searching and a coat hanger I got it back there without having to drill anything.
Here's where I put the amp
Then built the fiberglass enclosure
Old Jan 29, 2012 | 12:59 AM
  #40
M-bENZ's Avatar
Corrolla
It is loud but the bass is not clear ... Maybe my gain is too high then ?
Old Jan 31, 2012 | 02:29 AM
  #41
Jamesbbh's Avatar
Did you use a line out converter? If so, what speaker wire did you tap into? I tapped into the actual subwoofer wires and I still have the factory sub with my added 10.
Old Jan 31, 2012 | 02:44 AM
  #42
M-bENZ's Avatar
Corrolla
Same here I tapped straight it to the stock subwoofer wires ( disconnect the stock sub ) .
Old Jan 31, 2012 | 10:18 PM
  #43
Jamesbbh's Avatar
So can you give me a rundown of your entire setup? Like:
Mine is- Line level converter tapped to pick up signal from factory sub still connected--->rca's to amp I put in with factory amp still installed--->external 10" sub with factory 8" still intact. So my line level converter just picks the bass signal up from the factory speaker wires and converts it into a signal readable by my amp then powering my sub. It sounds like you may have some ohms or a filter setting off somewhere. Also, what kind of box is it? Bc sealed boxes tend to provide crisper bass while ported or bandpass boxes lean towards more bass but less precise. Hope that made sense? lol
Old Jan 31, 2012 | 10:37 PM
  #44
M-bENZ's Avatar
Corrolla
You don't have to use the line converter because the stock sub already have the low frequency ( I got the signal from here ) then RCA to Alpine Amp 500watts then from amp to the single JL Audio 10" Sub ( Sealed box ) . I think my problem is either the gain or the frequency from the amp is not right .. I might have the distortion that's why . There is a clip from YouTube showing you how to tune ur amp but I still can't get it right . The sounds is not that bad but I feel like I can adjust the bass to more clear ...
Edit : I have made a thread about this back then ... I even pointed out which wires/color to tap and more ...
Old Feb 1, 2012 | 06:42 PM
  #45
Jamesbbh's Avatar
Ok so if one end of your RCA's are into the alpine amp then what is the other end plugged into? I'm just trying to get a picture in my head.
Old Feb 1, 2012 | 06:58 PM
  #46
Jhuey's Avatar
CLK
Not sure where in Cali your at but there's a really good guy in Costa Mesa that ive been using. I am looking to do the same and he told me about 350 but this guy is really legit.
Old Feb 3, 2012 | 11:00 AM
  #47
M-bENZ's Avatar
Corrolla
I will post some pics if I can find it from my cOmputer .
Old Mar 3, 2013 | 12:34 PM
  #48
Anthony07's Avatar
Clk 550
I know you guys are talking here to add a subwoofer in the truck with an amp. But how can I also add an amp. For the speakers on the doors it doesn't sound that loud.
Please any help!! Also I was wondering if I disconnect the battery it will not ask for a code for the radio later?
Old Mar 3, 2013 | 03:01 PM
  #49
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
First of all, you can disconnect the power without worrying about a radio code. Second, your CLK550 has the Harmon-Kardon system, so there is no analog wiring in the dash for the head unit. Instead, it uses fiber optic cables to send the audio as a digital signal to the amp in the trunk. The amp does the digital-to-analog conversion along with amplification, and then it has high-level audio analog wiring from there to the speakers. So, if you want to keep the stock head unit and add an amp, you have to tie into the high-level outputs of the HK amp in the trunk - even for the door speakers. This mean using an amp that can accept high-level inputs, or use an adapter to convert high-level to low-level (pre-amp) signals.
An alternative is to replace the head unit with an aftermarket unit, then you have to run your own analog wiring to your amps (best to put them in the trunk), then you can tie into the speaker-level outputs there.
Old Mar 3, 2013 | 04:45 PM
  #50
Anthony07's Avatar
Clk 550
So the amp will be on the passenger side or the driver side by the fuse box.
Also so by this mean I will need to hook an audio control into the wire harness from the factory amp or not?
