Sqeal while turning and suspension "clunk"
Recently had the front brakes done. Did they miss something?
TIA for any input.
i may have overfilled it a bit, so going to use a turkey baster to remove some of the fluid and check it again. wish me luck
Interestingly, I was able to speak with a tech about it (we shared the shuttle back to the dealer, as he was dropping off a customer's McLaren SLR!) and he said that the reservoirs tend to crack or have leaky seals - and that's probably where my fluid loss came from. And that even if i had overfilled it, the reservoir cap is vented, and it would just overflow when hot, causing little/no damage.
So, longer term - I will look to replace the reservoir and associated seals, but for now keep it topped off with fluid. Total tab - $80 for dealer inspection and $34 for the correct MBZ fluid. Plus a turkey baster! ($3.95) for high-tech fluid level adjustment!
(Another note: according to the service writer I spoke with, this is one function that is NOT sensored on the 209, so best to manually check your fluid level as a precaution)
kevblah wins! good luck
