Dashboard Central Locking Switch Question
Old Nov 21, 2010 | 03:50 AM
Shockvalue's Avatar
CLK320
I have a CLK320 209
The central locking/unlocking switch on the dashboard is not operating the locks. Bit inconvenient when you want to stop to pick up a passenger when the car is locked(locks automatically shortly after initially moving off).
The central locking button on the key however works OK.
Is this likely to be a fuse or a problem with the switch circuit?
Appreciate any advice.
Old Nov 21, 2010 | 03:57 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
If it ws a fuse, the entire locking system shouldn't work (aka, key fob, central switch, etc.), sounds like a switch problem to me. Pull the panel, disconect the switch and plug it back in, could be something as simple as a loose plug.
Good luck.
Old Nov 21, 2010 | 04:52 AM
ahmadk's Avatar
2011 E550 Sedan
Good luck.
+1
Old Nov 22, 2010 | 12:29 PM
thegeneraltso's Avatar
05 CLK500; 07 Volvo XC90
If you don't mind driving with unlocked doors, you can disable the auto lock feature in the convenience menu.
