got her dropped =)
got her dropped =)
like the title states. i just lowered her on vogtland spring (thanks wes!) and koni shocks.
the current problem i am having is that i hear a clicking noise when doing a fast u-turn going towards the left or fast left. i know when i make a slow u turn or turn left slowly, i dont get the noise.
i have a feeling it has something to do with the wheel because when driving straight, there isnt a clicking sound. the sound is as if its a click per rotation of the wheel.
i cant figure it out and drives me crazy. lol not to mention, i cant have fun![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
EDIT: also when driving around at about 30 mph, and doing a slight solemn, i hear a hissing sound from the right front wheel. any ideas guys? im worried about the car since its my daily lol
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
The tire might be catching on the fender/liner. What Koni's did you go with?
They may. When parked turn the wheel all the way and get someone to push down on the corner of the car, you'll see right away where the issues are. You got the yellow adjustables?
Lol, Wes makes a solid point there bro - where are the pics?
its in the front. i swaped springs and shocks. and pics will come after i figure this problem out, and clean the car. working with the car+brake dust is no fun lol
im about to order spacers...just to clear the front suspension, too close at full lock anyways. i have 35 offset. should i sit somewhat flush with 3mm or flush at 5mm
and the rears....full flush with 10mm spacer?
04 CLK 320 > CLK32K
8.5 up front. sounds like its coming from the front right only.
The front should sit flush with either spacer, but those won't be hub centric. Only the 10mm is hub centric.
damn.....hmm i cant use them if they arent hubcentric right?
edit: turns out they touch at full lock......-___- so what should i do now?
lol at 10mm, ima be hella flush
well turns out, i found this company called ichiba
product: http://www.ichibausa.com/5mmalwhsp10.html
its a 5mm hubcentric spacer.i will sit flush. but i dont have a choice at this point cuz i rub at full lock.
i called the company that supplied me my previous bolts, they said i have 12x1.5 tapered bolts at 27mm long. so should i look at getting 32mm bolts?
for the rears...at 10mm, i should be looking to get 37mm bolts as well correct?
04 CLK 320 > CLK32K
Those spacer are not hub centric. The front spacers should have a cap on them that goes over the hub. It should look like this.
![](https://mbworld.org/forums/attachments/clk-class-w209/192544d1285375494-remove-end-cap-axle-system_2d.jpg)
I recently bought some lugs for Kevwood from RPMNorth and, for aftermarket wheels on the CLK, you use 28mm front and 23mm in the rear. So if you want to use 10mm spacers, you would have to use 38mm front and 33 rear.
04 CLK 320 > CLK32K
when i googled hubcentric spacers, all the pics done have a thing that goes over a hub but a ring that protrudes from the spacer. and i just took my lug from the rear, it measured around 27mm and the fronts use the same lug too. i dunno why but it does match up with what the sales rep said from powerwheelspro lol
The spacers with the ring are for the rear. I'll take a pic of my spacers in the morning to show you.
04 CLK 320 > CLK32K
I used 10mm all around.
Edit: This is how the rear looked. Keep in mind I am running 235/265, not sure how wide your tires are.
![](http://i852.photobucket.com/albums/ab82/Dynomite05/a4e4b79e.jpg)
ok so i am planning to run 10s all around. the pics that wes linked up look great. however, my bolts are 27mm stock. hr only carry 35 and 40mm bolts. so do i go longer or shorter?
