New Jamesbbh's CLK500 cab thread
Too many projects on the go with this car, need to get some done before taking on others!
Thanks Wes!
Didn't like the look of the aesthetics of the box so I started cutting away
Added some ponte fabric
Also didn't like the look of the amp cover I previously made so made this one
I presume you're going to glass it up and paint it to body-match?
Wes- yes that is usually what fuels late night work sessions haha.
Him-Fiance-Her two spark plug kids. Also, he's holding the "key to her heart" which is also a cam lock. Tonight I'm making a ball and chain to go on his leg haha.
220v twin cyl. 6.5 hp
This is the plug I'm using for it that was previously installed in the shop- It looks like a 3 wire going to a 2 pole breaker. What's odd is the wire looks like 4 or 6 gauge inside the box? Is that normal? There is also a cut-off switch on the other side of the shop that doesnt appear to work (or is connected to another outlet) I'll figure that part out later.
So I went and got some stuff to make a power cord out of 10/3
White/Black hot and green to pin
Wired it into the box to terminals marked "line-line" and "motor-motor" and grounded the motor and cord seperately inside the pressure switch.
Now problems:
- the motor wants to start but just flips the reset switch by the capacitors after about 1 second
- Motor started once and ran fine for about 5 minutes before I shut it off and now it's still flipping the switch.
- Motor was a little warm to the touch even before it started and ran for 5 minutes.
Is it the "run" cap that is causing these problems? Could it have something to do with the breaker itself? It's labeled for a 2 pole breaker inside the cover for the pressure switch.
Any and all help greatly appreciated!
Oh and a pic of my dog just for S&G's
