Oil Filter Wrench
Old Apr 15, 2011 | 07:45 PM
Yidney's Avatar
2008 CLK550 Cab
Oil Filter Wrench
Anybody know if there is an off-the-shelf oil filter wrench that works or do I need some Mercedes-only one?
Old Apr 15, 2011 | 09:42 PM
Moedy's Avatar
'05 CLK55, '04 CLK320
a strap wrench from a hardware store should do
Old Apr 16, 2011 | 02:13 AM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
For the M113 5.0 V8s (I think M112 3.2 V6s), you can use Autozone Oil Filter Wrench part #25401 Cap B.
Not sure about the M273 5.5L V8s
Old Apr 16, 2011 | 10:48 AM
Yidney's Avatar
2008 CLK550 Cab
Thanks. Picked one of these up and I can confirm is does work on the 550 engines.
Old Apr 16, 2011 | 02:44 PM
LexDiamonds's Avatar
2004 CLK500
Is the cap attached to the rest of the filter/ needle assembly? Ie- when you loosen the cap, the cap and everything else lifts out as one piece?
How does this oil filter wrench get grip on the circular smooth cap?
Old Apr 16, 2011 | 05:08 PM
Yidney's Avatar
2008 CLK550 Cab
The hole in the top of the filter slides onto a thing in the cap. The filter housing is not totally round. There are 14 flat spots around the edge at the top of the housing.
Old Oct 7, 2011 | 04:07 PM
rostrom's Avatar
2013 ML350, 2006 SLK280
I found a 75mm 14 flute oil filter cap wrench at O'Reilly auto parts that works perfectly for all 3 of my cars (2000 C230k, 2006 R350, 2006 SLK280). It is plastic, not metal, but fits enough to do the job. It was Pennzoil branded, part #19903 and was $5.99. Probably not as good and the MB part but thought some of you would want to know of this cheaper option. It works better than the 76mm 14 flute that Advance Auto Parts carries.
