Mounted my Garmin....
If you're really asking what the ball mount is, as opposed to the screw in it that does look nipple-like, it's a Garmin accessory, Item #: 010-10969-00, that was $5.
I had bought it make a really ghetto removable mount for the cupholder that I posted HERE. That spot was a pain in the butt, so I would just rest it on the open ashtray, which was fine unless I drove like an idiot, which I do often. I'm not a fan of mounting on the windshield, as I find that blocks my view of the road, which I think is a more important view. You gotta look down for everything else, like speedometer, radio, clock, etc, so why not glance down a little at the GPS? Like kevblah said, the COMAND would be lower. Plus, it's not like I stare at it while driving, lol.
As for how I did it, I followed Andy's instructions for removing the whole wood trim piece above the HU, then easily figured out how to get the switches out and drilled a 1/4" hole thru for the screw. Holding the nut with a roachclip while tightening the screw was the hardest part. Then, the second or third time I yanked the GPS off the blank switch came right of with it, which would've been a much easier install! Now I tend to leave part of the GPS mounting bracket to the ball, which ends up being able to hold my ipod, which I had re-routed the cable for thru the ashtray:
Garmin sells a lumpy looking bean bag dashboard host. Tom Tom
sells a flatter plainer on that I got. It works fine unless I am backing
down a steep driveway, and then it lands in my lap. It's called a
"universal dashboard mount."
