Project Dynavin - audio installation
I'm wondering on the placement and mounting of the amp. I would prefear not to mount it on the trunk floor and take up room. I was thiking one of the wheel wells, sides of the trunk or mount under the top shelf. The concerns I have is adequate venting as there is one or two fans on the sides. Also how secure it will be with all the shaking the car has.
How did you mount your amp(s)? Did you put any plywood under them?
lol funny thing, for me, JL made the coaxials 6.5 and the components "6.5" but really it was 6.75 so i had to fab a mount for it however, if they are true 6.5, they should fit no problem in the existing mounts
The trunk was easy going besides some stubborn bolts for the plastic cover on the bottom of the rear of the trunk. WD40 helped to loosen them up.
The rear side panels are a major pain to remove. Was going slow to not break or damage things. Do not have the rubber wedges tools but I used some plastic tire removal tools for my bike to help. I got stock on the removal of the seat belt holder on the floor as I'm apparently topping out on T25 size bit and I need T40 for this
It was late at night so will have to by one today and continue on. I have also thought about this and talked to a few members that did the same, and thats the separation of the amp power line and the signal lines from the HU by running them on the separate sides of the car. The OEM setup has power lines going on the same side as signal wires with no issues. Also there are other power lines on both sides so you can't really separate the runs. Therefore all I really need to run on the driver side is the extra set of speaker wires to drive the tweeters. The OEM setup has one set of wires for the front woofer and they split them out in the wire corridor in the front by the door. Thats where I will connect them to the wires going to the tweeter. As this is a thin pair of wires, I should be able to run them in the wire corridor and then route them under the rear panel and to the trunk with out completely removing the driver side rear panel and seat belt. That will sure save time. I think I will have to remove the panel on the passenger side to run all the other wires.
I spend a bit more time today and was able to run the extra speaker wire from trunk to the door panel. I did not need to remove the driver side rear panel just unclip it a bit to get the wires threw with a fishing wire. Although after I ran the cable I did remove the panel as it was partly off to see how it goes apart. Its back together now so that side wiring is done. Tomorrow I'm hoping to runn the power and audio wires on the passenger side.
http://cgi.ebay.de/DYNAVIN-DVB-T-Tun...item2564649703
Congratz on your purchase of Dynavin HU.
How is the peformance so far?
I had installed a unit to my 2006 W211 but facing poor radio reception..and same problem also happens on my other W203
Do you face the same problem...?
There is one thing which I dont really understand that the stock unit has two fakra connection on unit where 1 is black (RF radio antenna) and yellow (ZF). As shown as per below 1st picture..
but Dynavin unit has only one input for FM antenna as shown in 2nd picture.. this really puzzle me as i only connected the black cable to the adapter and to the dvn-mbe antenna connection, and left the yellow one (zf) disconnected.
I am wondering, leaving the yellow one (zf) disconnected would it be the possible cause of the poor reception..
How bout you? Did you left the yellow one (zf) disconnected as well?
Would like to hear your experience...thanks
Will the telephone cause any problem and is there any way i can find out if my stereo uses optic cable or not besides open the whole thing?
Do you think the dynavin would fit my car whitout any problems?
Witht eh Phone on the fiber network, you should have D2B fiber network, you will need to get a terminator plug to cover the fiber cable you unplug from the existing HU and one for the CD player if you have it. Otherwise the phone will stop working. Should not need any reprograming but not sure with that phone there.
Im not worried if the phone stops working, i dont use it anyway, i just hope it wont cause any problem on other functions.
This is exactly like the audio i have in my car, http://www.audio-10.com/Mercedes-Audio-10-CD-Radio-Becker
And i called Mercedes-Benz here in Sweden and the guy told me that there is no amp in the trunk and it dont run with the optic cable =)
Thanks for your quick answers=)
Now if you are after better sound then I'm sure you would benefit from replacing the speakers anyway and adding amp in the trunk. But thats far more expansive and much more work. Its what I'm doing now.
How's yours?
Did you get your CD Changer works with Dynavin HU? Mine CD Changer seems not working with it...
The phonebook is not functioning...
I am using the D90 platform . Previously D30 platform able to access this phonebook function...
How's yours?
I had a very bad month with far more work then I can handle. Its good and bad, but means that the car was secondary. I did learn how to remove the rear side trim taking lots of pictures. I have most of the cables done except need to connect to the battery. Then the speakers need to be replaced and hopefully over the 4th of July long weekend I will get that done. The rest should be a walk in the park, I hope
May I know what is terminator plug? Could you share the pic?
What happened if I did not terminate it? Sorry for the noob questions.
Good luck and all the best to you mate...
