Check Engine (Code 456) ???
Rating: Thread Rating: 4 votes, 5.00 average.
Old Sep 10, 2011 | 05:41 PM
M-bENZ's Avatar
Corrolla
Does anyone knows what that means ? Its my friend car (05-CLK500) . His car got check engine two days ago , i told him to go to Autozone and check ..and here it is Code 456.
Thanks in advance guys.
Old Sep 10, 2011 | 06:33 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Every codes have a description. Tell us the description !!!!!!!!!
Old Sep 10, 2011 | 07:28 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I assume the Autozone tool give your the OBDII standard "P" code which would be this:
"1089 Purge control system has a slight leak (minor leak) (P0456)"
If it's the DTC, then it's this:
"0456 The electronic analysis system for the O2 sensor in the engine control unit is defective. (P064E)"
Old Sep 10, 2011 | 08:25 PM
M-bENZ's Avatar
Corrolla
This is it,
so does anyone have this kind of problem before ? is it something we can do or it has to be done at the shop ?
Old Sep 11, 2011 | 12:36 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Could be as simple as a faulty gas cap, or filling up with the car running. See below
http://www.permoveo.ltd.uk/tabid/122...z/Default.aspx
Old Sep 11, 2011 | 03:01 PM
M-bENZ's Avatar
Corrolla
Mka77 ,
I will come to his house see if I can fix it and I do appreciate for that link .
Old Sep 11, 2011 | 03:51 PM
Mka77's Avatar
Mka77 ,
Welcome...Good luck with it.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
