High Flow Primaries
Old Sep 19, 2011 | 10:07 PM
togaclk55's Avatar
CLK55
High Flow Primaries
Thought I would share this with you guys. Just swapped out my stock primaries with thunderbolt high flow 300 cell metal cats. No CEL. Car is slightly louder at startup and cruising, but definitely louder at WOT from what I can tell. My setup right now is: stock manifolds->high flow cats->no secondaries->muffler.
Attached Thumbnails High Flow Primaries-img_0003.jpg   High Flow Primaries-img_0004.jpg   High Flow Primaries-img_0006.jpg   High Flow Primaries-img_0009.jpg
Old Sep 20, 2011 | 01:29 AM
ahmadk's Avatar
2011 E550 Sedan
congrats...
a sound clip would be nice
Old Sep 20, 2011 | 01:50 AM
Np55's Avatar
04 W211 E55 AMG
Would the cars ecu need to be adjusted if you swapped out all four for hi flow cats?
Old Sep 20, 2011 | 06:44 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
If you dont throw a code by changing out the primaries then no, the secondaries do not have O2 sensors before and aft. Its good to know 300 cell work with the car in stock trim, I had always wondered it they would throw a code.
Old Sep 20, 2011 | 07:34 AM
betrezra's Avatar
C63 507 AMG DA Car #19
I have heard the labor to do this was expensive and difficult. Did they have any issues with the install of the primaries?
Old Sep 20, 2011 | 10:46 AM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
Thanks to adding to our W209 tribal knowledge Togaclk55!
In addition to the questions above, I would like to know if you're going to smog your car? It would be great to know if it passes the California smog sniffer test!
Old Sep 20, 2011 | 11:22 AM
Supafly's Avatar
I drive the racism out of BadDebt. ;)
Up here in BC, our smog test is just and OBD port....lol. If you dont throw a code; you pass.
So technically, I can straight pipe it with Hi-flow primes and pass.
Old Sep 20, 2011 | 04:30 PM
togaclk55's Avatar
CLK55
congrats...
I'll try and get a sound clip, but no guarantees
Not too sure about this, but I heard the ecu will readjust over time...
Nope, the install went pretty smooth, just had him fit the HFC between the o2 sensors. He had to cut some of the ends off the cat to make it fit. Cost me $140.
It should pass the sniffer test, there is a guy with a SL600 running this setup and he passed.
I used these 300 cell cats w/custom downpipes from my Turbos, relocated O2 sensors & bungs NO check Engine lights & recently passed stringent CA SMOG w/NO tricks on crapy 91 octane. They're surprisingly afforable & durable been on nearly (2) years now...
[URL="https://mbworld.org/forums/clk55-amg-clk63-amg-w208-w209/317532-metal-core-high-flow-cats-now-only-75-ebay-2.html#post4653930"]
Old Sep 21, 2011 | 03:28 AM
Kevwood's Avatar
I do miss Canada sometimes...
Old Sep 24, 2011 | 07:35 AM
togaclk55's Avatar
CLK55
Originally Posted by ahmadk
congrats...
Here ya go, a little startup vid: http://www.youtube.com/watch?v=JaPjBQ0hVxc
Old Sep 24, 2011 | 11:42 AM
tkhuuyip's Avatar
W209 Clk55 W140 S500
Sounds nice. How much were the cats
Old Sep 24, 2011 | 03:31 PM
togaclk55's Avatar
CLK55
$60/cat
http://cgi.ebay.com/ebaymotors/2-25-...item2eb7f62512
Old Sep 6, 2012 | 02:54 AM
sleepyheadzzz's Avatar
2000 Volvo S40, 2006 Hummer H3, 2008 CLK550
The link States the diameter is 2.25 inch......would 2.5 inches work?
Has anybody tried 100 or 200 cell
Old Sep 10, 2012 | 08:33 AM
bheng's Avatar
2003 CLK 320
hows the sound under normal cruising? and im assuming it gets progressively louder as you hit it.
willing to consider this just to get a little more umph when i push it =p
