"Keyless Go" Testing
Old Nov 10, 2011 | 11:00 PM
eng_nz's Avatar
W209 CLK
I bought a 2004 w209 CLK 11 months ago. It has the keyless go system. I can start the engine. I can lock and unlock via the boot. I can unlock from the driver's side but not lock. I cannot unlock or lock from the passenger side.
I finally decide to DIY this frustrating problem.
I searched the net for all possible solutions and discussions on this issue. There are quite a few articles and discussions out there.
Basically, most indicate the problem is the actual door handles themselves. At more than NZ$500 a pop and that is not a cheap solution.
I needed a way to test and confirm this is indeed the problem before ordering a new handle.
I can happily report that there is a way to test your "keyless go" door handle to confirm they are faulty or not.
Also I have not found any articles of what is inside these keyless go door handles...so I decided to take one apart; get some photos and enlighten others.
See attached PDF files....
File Type: pdf
Old Nov 11, 2011 | 05:11 AM
eng_nz's Avatar
W209 CLK
2 more files added
Old Nov 11, 2011 | 09:40 AM
ambit's Avatar
09 CLK550
The wires in the driver-side handle of my car had worn down and the keyless go would no longer work on that side. Thankfully it was only ~$130 here in the States.
Old Nov 11, 2011 | 11:12 AM
Frank Rizzo's Avatar
2024 GLE63s
Thanks for this!
I saved all the files and it will probably be a few years before I appreciate them, like a fine wine...
