Audio volume auto ??
anyways. I notice when coming to a stop by stereo volume will go down then go up when I drive off ?? What gives ? I looked thru the settings and couldt figure it out. :-/
Thanks Schmitty63- ya I searched around and found out it's some kinda Bose volume adj. I'm guessing my local MB dealer can turn that function off. ?
Re: Clk 500 Low Fi Audio
Quote:
Originally posted by Jksellman
1. It has an automatic level control that makes the volume louder and softer depending on road noise. The litt says this is undetectable, but I find it very detectable and annoying. I had this same "feature" in my Porsche, but I found out which wire to disconnect from the stereo to defeat this "feature".
there are actually 2 systems working. 1 is the bose audio pilot which is supposed to be undetectable (but i can still discern it...). the other is the speed-sensitive volume adjustment. that can be disabled thru the DAS at your dealer. well, i should say that that is the way it is for the C-class, so i'm assuming that the clk would be similar.
__________________
