Changing Air Filter
Old Jan 1, 2012 | 08:44 PM
mis3's Avatar
2004 CLK320
Changing Air Filter
I like to change the air filter of my 2004 CLK320.
Is there a DIY writeup on this? Also need the instructions how to remove the engine cover, don't want to break any clips.
Old Jan 1, 2012 | 09:52 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You shouldn't break any clips removing the covers - they use very solid metal spring clips and rubber knobs. Remove the front part first, then the two cold air intake tubes, then the main cover (that is actually the air filter housing).
Old Jan 1, 2012 | 10:28 PM
mis3's Avatar
2004 CLK320
I never saw how to remove the engine cover. Do I just pull the cover upward?
Old Jan 2, 2012 | 12:01 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
To remove the front piece, pull up on the front edge and then slide forward. The intake tubes just have to be pulled loose from both ends. The large cover (air cleaner housing) just pulls straight up. It has two metal clips on the front, and the rear rests on the MAF sensor housing. When you replace it, make sure it seats properly on the MAF sensor.
Old Jan 2, 2012 | 01:11 PM
mis3's Avatar
2004 CLK320
Thanks Rudeney.
I did manage to remove the front piece. To remove the larger cover, do I pull up?
I saw 2 intake tubes on both ends, do they pull right out?
Any screws to remove when changing the air filters?
Old Jan 2, 2012 | 01:18 PM
Yidney's Avatar
2008 CLK550 Cab
Originally Posted by mis3
Thanks Rudeney.
Yes, you pull up - and slighty forward - just like Rudeney said. There are torx screws holding the covers over the actual filters. But no screws to remove the housing from the car .
Old Jan 2, 2012 | 01:22 PM
Yidney's Avatar
2008 CLK550 Cab
And by the way, I buy original MB air filters. Not because they filter better or I'm a purist - but I tried aftermarket once and the sealing foam around the edge was much stiffer than on an MB filter and deformed the cover when it was tightened down. I didn't like that, so I got originals.
Old Jan 2, 2012 | 01:25 PM
Yidney's Avatar
2008 CLK550 Cab
And also by the way - the intake tubes can be hard to slip back on fully if they are even slightly cold. Shoot a hair dryer at the end for a minute and they will slip on much easier.
Old Jan 2, 2012 | 01:31 PM
mis3's Avatar
2004 CLK320
Sorry, i am confused Do i remove this torx screws or not?
Old Jan 2, 2012 | 01:37 PM
Yidney's Avatar
2008 CLK550 Cab
Yes and no. You have to unscrew them, but they do not come completly out. They are designed that way. You are not going to break anything like you seem to fear. Go grab your housing and wiggle it up off the engine. You won't hurt anything. Flip it over and you will see the screws.
Old Jan 2, 2012 | 03:26 PM
bheng's Avatar
2003 CLK 320
the only thing you might break is the front of the airbox which is ot attached by the metal clips.
all i do is remove the intake hosing and then grab the intake at the center gently pull upwards. should come right off. its one of those things you will know what to do next after you flip it upside down.
gl
Old Jan 2, 2012 | 04:23 PM
mis3's Avatar
2004 CLK320
I just remove the rear engine cover and the air filters are in inside the engine cover !!!
Thanks all for your help.
It happened that the air filters were not dirty at all. The last 2 times they were changed were 03-Jun-2010 and 26-Mar-2011.
So, I just banged them against the wall a few times until no more dust and put them back on. I did see some 'sand' (???) in the air filter housings which I blew off. I will replace the filters in maybe 6 months.
Old Jan 2, 2012 | 04:30 PM
bheng's Avatar
2003 CLK 320
i found a couple of bugs in mine lol...and a cig butt
Old Jan 2, 2012 | 05:42 PM
mis3's Avatar
2004 CLK320
I sure hope I did put everything back correctly.
If I didn't, would I get a mallfunction?
Old Jan 2, 2012 | 07:09 PM
user 823908234's Avatar
mis3, you sound like me... all worried... until I started reading all the great info on MBWorld. The guys that hang around here are absolutely the best when it comes to information and help. And they got me to "Just do it"! I've worked on my cars and bikes since the early sixties, but these newfangled techno-rockets are somethin' else.
(Thanks to all the MBWorld guys... you are the BEST!)
:-Jerry
Old Jan 2, 2012 | 07:28 PM
Yidney's Avatar
2008 CLK550 Cab
The only thing that can sometimes be an issue is not getting it seated fully over round air intake at the rear. Just make sure that is fully seated. It can throw a code eventually, but the bigger issue is sucking unfiltered air into the engine.
Old Jan 3, 2012 | 01:25 AM
billyhead1's Avatar
CLK 320
there's another writeup out there, but this is a good start. if you search this forum you will probably find a link to it....
http://www.benzworld.org/forums/w203...er-change.html
Old Jan 3, 2012 | 03:13 PM
mis3's Avatar
2004 CLK320
I checked.
I pushed on the rear engine cover and found there was little or no wiggle room underneath. So, it must be installed properly.
Old Jan 7, 2012 | 12:28 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
There should be enough room to put your fingers on the underside of the rear cover to feel and make sure the cover is seated properly over the MAF sensor gasket.
And this doesn't apply to the OP, but some engines have a vacuum hose attached to the front of the rear cover, sitting right on top of the engine. If yours has this, don't forget to reattach it.
Old Jan 7, 2012 | 02:38 PM
mis3's Avatar
2004 CLK320
I re-attached the 2 intake hoses when I put back the rear engine cover but don't know about this vacuum hose.
I have driven the car for 2 days and did not notice any irregularity.
Old Jan 7, 2012 | 07:40 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yours doesn't have the vacuum hose -that's only on the 3.5/5.5 engines.
