doctor color chip!
CLK 550
MBworld Guru
I'm not crazy about it. I tried it on the C240 which is "Desert Silver". The process works OK, but their metallic color doesn't match well. It actually doesn't mix well - it's very splotchy looking. I actually prefer using OEM touch-up paint. If it leaves a blob, I use Langka (see langka.com) to remove the excess and then 1200 grit wet sanding and polishing compound to clean it up.
Mercedes CLK 320 W209
19 C300
I have heard good things... Also may from the BMW community are sold on this product
http://www.langka.com/
If you do either... Be sure to do a thorough write up for DIY
CLK 550
so this stuff works...!
its not PERFECT ... but covers about 80%
for deeper chips it fills them in color wise - but if you look closely you will still see the paint chip defect
but definitely NOT noticeable unless you look very close
pics to come
pics to come
